Post Info TOPIC: Winter work on 71 Convert, Round 3
After taking a lot of pictures of Andrew and Stan's cars, plus a few measurements, i have concluded my car had major rework on the rear prior to the first yellow paint job.
Clues were Lead on the seams at the top, no blue layer on the rear fenders and a once green trunk lid. the final proof is the opening width at the top is ~3/16 to 1/4" wider than it should be, the bottom more like 1/8" too wide. Not sure what i will do with this information, the PO had used Bondo to fill the gaps. Have seen several ways that this can be fixed, not sure i like the prospect of any of them.
One more reason to just "Fix up" as a driver and refer-bush, Vs. a full restoration....
Also started the process of replacing the frame mount rubber bushings. After weeks of soaking with liquid wrench and PB Blaster, drilled 1/8' holes to access the cage nuts, the first 3 still broke off with out a lot of pressure. the 7/16" bolts snapped in areas where they were mote like 5/16th. will likely have to open up all of them from the top and replace the cage AY. Good news is this means thet progress is being made. Mitch's Sawzall attack under Andrews car was an inspiration to dig in and just do what it takes.
12 years ago, I was in the same place with how to do repairs that seemed daunting. I read about how others had done the job and at the end of the day, bottom line is, you just need to get out the big tools and start slicing. it's difficult to get past the doubt of in-experience, but after a short time, and a couple successful repairs, you will gain the confidence to just dig in and git-r-done.
On the wide trunk opening, if there is work needed on the extension panel, between the top and trunk lid, you can slice that at the quarter seems and pull the side together rather easily with a come along and a couple home fashioned hooks to grab the seal gutter underneath. The trick will be to determine which side needs to move, or both, and how much, to keep the opening square with equal lengths. Drilling an 1/8" hole in the same place on both quarters, near the extension panel, as a measuring point is a good start for consistent numbers. If the hole would be an issue from too much curvature across the measured area, you can ad a Phillips head machine screw of appropriate length, to raise the measure point above the curvature.
I'm sure Karl would be pleased to run over from Crystal Lake and help with this, if you want.
Or, I could find a time on a weekend to run down and assist getting this set-up for you too.
Almost ready to start replacing the passengers side frame cushions. Thinking they really needed to be replaced rolleyes
Despite weeks of soaking them with PB Blaster and 3M penetrating oil, they either broke or spun the cage nut mount (ordered a whole set)
A few more patches will be needed.
-- Edited by BLyke on Tuesday 8th of May 2018 10:09:14 PM
That car is darned lucky it came under your care...thumbsup
Is there a bolt in the mount hole under the seat on your convert ? I was surprised to find a dead plug mount on andrew's car in that position. There is a cage nut in the floor support for a bolt.
Yes there is, and it is under two layers of steel. thought i missed the location, so move over ~2 " and tried again, only to not find it. Good thing i was a welder in my younger days.
As far as the car being lucky... more like a shelter for strays? I always see the potential and thing the car can be saved.
Perhaps the next build will need to be a rust free rolling shell, the bolt on stuff is way more straight forward.
There's a reason I travel so far from home for cars now....much less rust....and the adventure of retrieving them...cool
yep
Guess when it has been a month since the last progress report, there may not have been much. rolleyes
Had some time this weekend and finished up the frame mount cushions. This included replacing all of the cage nuts and making new "plate nuts" for the ones on each side of the seat mounts, started welding up the patches for the holes that had to be cut. After that it will be on to some floor panel replacements.
Hope to keep the momentum on the "Summer Project", may even be able to avoid it becoming a "Winter Round 4"
-- Edited by BLyke on Sunday 10th of June 2018 09:56:44 PM
The potential progress has taken a sharp up tic as of today. As a result of further "reductions in force" my days of working for "the company formally known as Despatch" are over.
So on the plus side there should be time for summer work on the convert, which is nice,..... so I've got that going for merolleyes
Sort of sorry to hear of your lay off. Retirement is fun for the first several months and then you run out of money for the big dreams...laughingOh, maybe you won't go buy an additional 3-4 cars...banghead
I did end up using the listing wire I got from you in my '62 seat upholstery. Much of the old stuff was stained and I didn't want to re-use it, so I ended up buying a 70 ft roll too. If you need more, let me know..thumbsup
 Thanks Mitch, having a much smaller shop (and Lakeville ordinances) will help limit the size of the herd. As you know there is still plenty to do on the 71. Having ~6 to 8 times more hours for working on it should get it done a lot faster.
Sorry to hear that Bruce.  Something will work out assuming you want to find a replacement job?  I've got a few connections out there in the supply chain network if you're interested, as I think that's your profession?  Hit me up on Linkedin, and you can check out my network.
Or, maybe you're in a position where you can take a break from things, which would be a great position to be in with the vert project calling your name.
Thanks Stan,
For the moment, it option #2, taking a break and test driving being retired.
Longer term is still TBD.
Time for a weekly update
ready to weld in the new floor on the drivers side front, perhaps tomorrow.
That should be fun. A person can make more progress when having the time to putz all day, instead of trying to squeeze project time in after a work day...thumbsup
 Yep, got it all tacked in before i had to head out this morning. did a few rounds of trimming and grinding to improve the gaps.
Made a~2 X 6" piece to go in a small area behind the front patch that was suspect
Front floor just needs a little more clean up and seam seal and it will be GTG.
Cut out the major bad rust and previous work on the passengers side, leaving the solid area.
Considering attempting the full panel replacement. More work to remove and prepare but will look better, just in case it takes a while more to get the rear seat inrolleyes
-- Edited by BLyke on Wednesday 25th of July 2018 09:06:30 AM
Had to go up higher too on the drivers side, removing flat patches on top of rusted parts and then cutting them out.
Will have to fab up the two layers then on to installing the the whole new panel.
-- Edited by BLyke on Tuesday 31st of July 2018 08:33:49 AM
It's going to be so purdy, when you are done.
Interesting that it has the control arm braces. Wonder if that is because it's a convert, or was the car an SS ?
Lookin' good Bruce.
Mitch-The braces must be a convertible thing as the '72 vert I had also had the factory braces like that and it was a Malibu/Non SS.
Thanks Guys, it will be a lot better and covered by the rear seat  (that also need to get redone!)
Thinking the braces is convertible, as i have the build seat and the car was not a SS, but it will look a bit like one when it is done~?!
-- Edited by BLyke on Tuesday 31st of July 2018 10:53:50 AM
Getting there.
Looks great Bruce, I just painted my on again off again floor pans and trunk project.
-- Edited by dashboard on Friday 3rd of August 2018 06:47:47 AM
Thanks, yours actually look great (as in better than new)!
I'm happy with the improvement on mine and that there are no longer flat slabs of sheet metal scabbed here and there.
Mitch tried to warn me.. starting on the rear passengers floor next. Just got the pan delivered
When exactly will winter 2018/19 start??rolleyes
 In about 8 weeks, so you are ahead of schedule...thumbsup
Replaced the passengers rear floor (that i had made a small patch in sometime ago) still need to clean up the welds and prime.
It was so much fun... will be ordering the rear drivers side, and then that is it........rolleyes
the passengers front will be just fine as is....
-- Edited by BLyke on Tuesday 4th of September 2018 05:48:01 PM
-- Edited by BLyke on Thursday 6th of September 2018 02:19:11 PM
-- Edited by BLyke on Thursday 6th of September 2018 02:20:18 PM
-- Edited by BLyke on Thursday 6th of September 2018 02:21:11 PM
Thanks to Hank, Stan and Derek, I have made it back to the forum, after operator error on my part lost my info.
Floor is now sealed and the project is moving forward to the doors and front fenders.
Seams to be getting to the point where i will seal the deal?
Looks good Bruce!
I noticed it looks like you used the galvanized floor plugs.  Just a note that paint doesn't like to stick to them, so suggest a good scuff with a Scotch brite pad before priming/painting.  Especially if you put any in the trunk area and try to spatter coat them.  I had issues with that when I restored the vert.
thanks for the tip on the plugs Stan.
Looks great, Bruce. Can we expect to see the car at club events next year...stirpot
Looks good!
Larry Lucast wrote:
Looks good!
 And what became of the buffing process on your car...headscratch
 That is the new plan, hopefully i will not need to buy a trailer to make it happen.
 It's cheaper to rent a trailerlaughing
 That would be pretty cool....pull the vert with the '59...thumbsup
Did not take a before picture, but here is a bit of "extreme detailing" of the fan, which had rusty blue paint and dull blades with some sort of brown streaks.
Starting to get it back to the point it can be moved out of the garage so i can get it ready to prime.
Looks good Bruce.  It looks like a factory fan but with stainless flex blades?  headscratch
Ya, I think they might be SST.
FWIW Bruce, I had a flex fan like that and ended up replacing it with a factory AC fan to keep the temps in a normal range on a SBC.  If yours is staying cool, no worries.
Thanks Stan,
No A/C and the engine runs cool, at least as i recall from ~4 years ago. Lately is is always at room temperature.rolleyes
Saw one like this listed for $99 in a Chevelle catalog that came with the blue paint.
-- Edited by BLyke on Thursday 11th of October 2018 11:11:22 AM
Guess it is about time for a update.
Beginning to reassemble the front end and wiring.
Plan is to lock down the semi-gloss parts and set the gaps, then pull the outside parts of for painting.
Grandson spent some time helping out and learning to read Assembly drawings and how to calculate the +/- tolerances, then how to measure them.
You're going to DRIVE that car next year, aren't you...cancan
There's very little yellow left on that car.  I like it!
Great teaching opportunities for the grandson too.   thumbsup
That is the plan!
 Thanks Stan,
All of the grand kids like to help and learn with hands on work,
Ever wonder how to measure the exact width of a cowl hood? one way is with a wooden caliper like this.
setting up the fenders for proper gaps
-- Edited by BLyke on Thursday 15th of November 2018 11:50:06 AM
Ever wonder hos to measure the exact width of a cowl hood? one way is with a wooden caliper like this.
Nice template.  Hopefully the hood stamping is consistent from side to side, but that should get you in the general area from what I know... cuckoo
I'm sure Dashboard is happy that you're utilizing wood somehow in your project, as that's his thing.  razz
The hood is a GM OEM part and very consistent top to bottom thumbsup
«First  <  1 2 3 4 5 6 … 8  >  Last»  | Page of 8  sorted by
