Post Info TOPIC: Not a Chevelle, but it is a project
Since there were no Chevelles made in 1963, thought it would be to show a few updates on my 1962 Rambler Classic 770cool
First thing was getting rid of the nasty padded dash
RC Dash 3.jpghaving trouble with pictures
the previous view was the prototype mockup before i cut up a good piece:cool
:rc 63.jpeg
-- Edited by BLyke on Thursday 29th of May 2025 07:48:04 PM
-- Edited by BLyke on Friday 30th of May 2025 10:58:13 AM
-- Edited by BLyke on Friday 30th of May 2025 10:59:17 AM
Think the 770 will be ready for BTT50's next week.
As of tonight, it should be a go, remaining items should not be too bad and most of the hard to come by parts are here nowrolleyes
Looks really clean. Should be an easy detail job.
BUT, you are wrong, grasshopper, there were many Chevelles made in 1963, as assembly started in August, 1963...stirpot
Good point Mitchrolleyes
Progress, cleaned up "barn find" spinner wheel covers
-- Edited by BLyke on Monday 17th of November 2025 07:39:45 AM
-- Edited by BLyke on Monday 17th of November 2025 07:40:41 AM
Wow, Bruce, super job !!
Good to see you Saturday and that you are enjoying a little "project time" again.
Wow, huge difference! I wouldn't have guessed those would clean up so well.
Thanks guys!
Hope to get the car back next week from the transmission shop and get going on a few things
Thanks guys!
Seems I was a bit too optimistic,,,
Got the car back on Monday the 8th of December, the transmission worked well on the 7-mile test drive homethumbsup
Will be getting going on a few smaller items as time permits
-- Edited by BLyke on Wednesday 10th of December 2025 05:33:53 PM
With winter full on in Minnesota and the work on the Rambler is getting going
Backup light lens was removed to check the bulb, leading to a need for a new gasket. this also confirmed the problem was not the bulb. Suspect the Neutral Safety switch is bad.
It also allows the car to start in any gear so i think i will order a new one
Door locks did not work. The passengers lock just needed some lubrication and now works. The driver's side will need some more involved repairs or replacement.
While the door was apart, I reglued the side of the cover.
Nice work on the gasket !
As a small piece of experience to share, paint stir sticks under your door covering clamps prevents the clamps from denting the vinyl, yes the dents come out eventually, but the sticks help eliminate any doubt.
I now have a pair of functional Locks, .... so, I've got that going for me
Which is nice.
Moved on to the dash cluster area, things were really loose, especially the ignition key area
5 screws, some new foam and a nut and it is very solid.
The ignition switch was basically held in place by the wires, found the mounting tab after removing the ash tray
Seems a PO had it apart and didn't quite get back together all the way
-- Edited by BLyke on Wednesday 24th of December 2025 01:17:30 PM
-- Edited by BLyke on Wednesday 24th of December 2025 01:19:44 PM
The trunk springs did hold the lid open, short term a piece of 1 by was cut to length. Further investigation revealed the right side was severely damaged. The left side was black and obviously not original. got a replacement (in blue) for the right side and painted them to fairly closely match. Will line up some help to remount the lid but moving on to some other items.
I am baffled as to how the damage would have happened, but at this point it is not important
It was a battle, but the backup lights are now functional cool
It finally dawned on me that the voltage meter will show up with very little amperage compared to the bulb
Ran a jumper from the negative battery terminal to the bumper to confirm my concept and lights worked.
Since this is a "fixup" a budget friendly solution was utilized grounding, body to bumper bracket and its GTG
Not sure why the pictures got rotated, please use your imagination rolleyes
-- Edited by BLyke on Monday 19th of January 2026 10:27:48 AM
My friend Scott was able to lend a hand, and we got the rear end and torque tube out
Getting the old rubber trunnion out took some effort, as did getting the new one on
The rear seal was the source of the gear oil leak
General clean up continues before reinstalling
Will be replacing shocks, drums and shoes "while I'm at it"
