Post Info TOPIC: 1952 Pontiac Catalina Hardtop
RE: 1952 Pontiac Catalina Hardtop
Larry Lucast wrote:
That is nice looking.
I am jealous that you are getting things done while I am mostly procrastinating. Whose fault could that be?
 Your wife's...dunno
Pulled the old shifter linkage and did some troubleshooting on the range of movement.
From the looks of things, the PO put the engine back a bit too far, with homemade engine and tranny mounting supports. the shift lever on the column hits the valve cover.
It looks like I can cut off an inch or so, it is currently about 5" from the center of the shaft to the current connecting rod shaft.
Have a Lokar (or that style) kit on order and looks like this will allow a normal range to all gears.
Currently it was not possible to downshift to 1 & 2
It appears the arm on the shift shaft of the column could be loosened and rotated up, for more range before hitting the cover. That would require the super heavy duty welded rod to the trans to be longer and I don't see much length at the top swivel for that.
it actually hits the cover at the mid-point of the range, can only go down.
it is almost hitting the firewall now, so choices are limited.
Think taking an inch off will do the trickrolleyes
-- Edited by BLyke on Tuesday 14th of December 2021 06:09:11 PM
If you need it cut and welded, I know where that can happen...thumbsup
 We will see, think just cutting and drilling a new hole should do it.
There is a ~3/16 hole closer to the shaft that may work out,
Once the new parts are here it can be mocked up, probably will get it cut before so it has the full range of motion
Are you working on the Camaro this winter?
Haven't yet, but I dug it out of all the "stuff" I piled around it all summer over the weekend. I REALLY need to get back at it. I have an inquiry out with a guy in OK that has an NOS tail panel and right front fender too. It would be nice to have to make a quick road trip...cool
Hope it works out on the NOS parts, seems you are always up for a road trip when parts or a new car are involved.
 Or winter vacation in Florida...nana
That is a good option too!
Well with a bit of effort, some cutting, welding, rework, Boy Scout knots, as well as some trial and error, the Catalina now has a fully functional gear shift.
The lever on the column no longer stops at the valve cover.
The Parking brake has a new cable and is fully functional. the speedometer drive gears have been switched and should soon provide an accurate indication of MPH.
The old semi-shiny gas cap without a seal has been replaces too with a new one with a decent seal
-- Edited by BLyke on Sunday 19th of December 2021 02:07:26 PM
-- Edited by BLyke on Sunday 19th of December 2021 02:08:42 PM
At this pace, you're going to be ready for cruising season in 2 weeks...thumbsup
 Have you been using the time away from working on the Camaro to work on your stand-up comedy routine??rolleyes
It will be good to go for BTT50's for sure.
Have some home projects that will be starting after the holidays. thumbsup
Progress continues
Now have a functional shifter and a reasonably accurate indicator
Looking great, Bruce! If my old man and I come to BTTF this year, I'll have to find you.
 1968 Malibu
Gavin H. Otsego
Yearend update, hope to keep making progress and will be making updates every 1-2 weeks to help stay on track.
Feel free to bug me if it seems that things have stalled rolleyes
Updated gauges to use a chrome mounting that was in the Nomad when I got it.
Working on rerouting wiring, may have to shorten most of it, good news is ~75% was completed and working. adding 12 volt wipers, th400 kickdown, Backup switch and Neutral safter Switch, as well as a Small "defogger" just to have for a rainy day
the little one purchased was way too weak, so im making a "hot rod version" with much larger and higher static fans, we will see how that goes,
Happy New Years to all my NSC friends!
HAPPY NEW YEAR to you too, Bruce !!!
That car is lucky it fell in your capable hands. it will be a lot better when you are done with it.
Thanks Mitch, someone needed to do itrolleyes
Happy New Years to you too!
Time for an update....
The new wiper motor is now in and the switch was modified to go in the top of the dash and use the original knob
Also have the heater ready for some paint and then installation, there will be plenty of air going to the windshield which was the main goal
Well, look at you, Mr. Tinsmith !! That defroster housing looks might nice.
I have New Port wiper system in my '38 as well and the control knob was originally on top of the dash then too. They sure didn't change placement of that for a long time. The PO of my car mounted the tach up there, so the wiper control is under the dash. I hope you bought the intermittent controller as well. On misty days, it gets really old turning those wipers on for a couple cycles and then off for 30 seconds... I keep telling myself I'm going to get that "this year". Uh, huh, I've had the '38 for 9 of those "years" now...rolleyes
I should just go online and order it, and new blades, right NOW, except I can't remember if the blades are 7 or 8".
Only went with a 2 speed, which is a big improvement from the original, that was nonfunctional
As you know there were variable speed, well actually 1 speed but would stop when passing or driving up a hill, they literally "sucked"rolleyes
Progress is steady but slow, as the rework on the wiring is getting done. Hard to see the progress but it is happeningrolleyes
Already appears far more neat and orderly.
I see you removed the belt clip from your Milwaukee drill/driver too...thumbsup
 thanks, and as I recall the belt clip fell offrolleyes
Here is one of the before pics
Progress continues, decided to rip out the remaining firewall insulation which was pretty bad shape.
This made it a lot easier to finalize the location of new Heater/Defroster
Will clean up the rust and put something on the firewall to help with heat and noise.
I have massive quantities of Foil backed stick on insulation.
More than happy to donate towaed your firewall project.
Product, in stock, at the Treasure Chest.
Let me know if you would like some.
Thanks Karl,
The Plans may be going to a Phase II next winter and involve moving the battery location to the driver's side fender, which would require cutting the insulation up.
If I swing back towards putting it non now i will happily take you up on the generous offerthumbsup
-- Edited by BLyke on Monday 7th of February 2022 08:08:14 AM
Off topic comment...Bruce I'm not sure when you changed your avatar pic, but seeing that nice sunny warm day pic with your cars outside really warmed my heart to know we will get through this long and cold winter and how much I'm looking forward to driving the Chevelle again! Thanks for sharing it.  beers
Glad you liked it, not sure how long ago this was, but like you we are looking forward to getting back on the road!thumbsup
So here are a few more updates
- Finished the plumbing for the heater
- Started on plans for a 3RD Rear light, using the same type that was in the Nomad
- Made a glove box out of an old file box I made in the 70's (the heater took up several inches, the old one was a former mouse hotel)
- Added a set of headlight visors.... Just for fun? (Or do they help keep the car "Cooler" in the summertime?)rolleyes
-- Edited by BLyke on Saturday 12th of February 2022 05:11:05 PM
The visors make the car cool anytime.
 Might have to keep watch over them. I'm sure they would fit my '54...laughing
Your glove box liner is another work of creative art. ..thumbsup
At least you did not commandeer "eyelashes" off a VW.
beers
Make it YOURS!!
Thanks Guys, appreciate the support and encouragement!
Now to really focus on the electrical, it is getting there but taking time so hopefully will not make "Short" work of it,
-- Edited by BLyke on Tuesday 15th of February 2022 05:17:12 PM
-- Edited by BLyke on Thursday 30th of March 2023 06:22:32 PM
"hopefully will not make "Short" work of it,"
GROAN!!You should be ashamed (or proud) of yourself.
Happy to say the wiring for interior lights and switches has been sorted out and is now ready to go.
It’s toward the end of the rewiring list since it is not “necessary”. There was not a lot to start with as much of the existing wire and parts were gone or needed rework. To figure out how to get 4 lamps and 4 switches to all work in harmony a lot of jumpers with alligator clips were used. Only 2, 15-amp fusses were blown. Discovered there is a back seat switch for the lamps, its on order and will just need mounting on the rear driver's quarter panel cover. Made my own larger schematic to check off parts of the circuits as they were confirmed.
 Also have a functioning Neutral Safety switch mounted under the car to the TH400, Reverse light switch and Kickdown switch. I will spare the details unless someone needs to know the process used.
 Wiring and sensors for the oil and water temp are next
Functional lights
Those opera lights are sexy !!
And the under-dash lights remind me of the 71convert. Was thinking perhaps they were part of the new "Hardtop convertible look"?
Back up Lt.jpgFinally,cool
it really took a lot of other work to get to where I could hook up 2 wires for the back-up lights
-- Edited by BLyke on Friday 25th of February 2022 04:20:21 PM
Sequences... kind of like the Mouse Trap game.
Lights look nice.
Now, take a piece of 4X6 and make a buck to match the bumper and we will push those dents out on the press...thumbsup
Lights look nice.
 Thanks
I may let the bumper wait a bit and stay focused on functional areasrolleyes
I didn't mean this week. Maybe a summer tech session, club picnic on Plainview Drive ? WITHOUT the rain..thumbsup
 Perhaps by summer I would be up for itthumbsup
Completing this build is taking a lot more than anticipatedrolleyes
They always do, but what else do you have to do during winter ?? There's always next winter too.
My long range goal for next winter is to have the '70 SS in the shop for sheetmetal replacement.
Sounds like a good plan Mitch
All electrical systems are a go, at least all of the ones I was working on and need to drive safely and legally.
A few nice to haves were tossed in too
-- Edited by BLyke on Thursday 10th of March 2022 09:59:21 PM
Most Excellent !! You are ready for cruising...thumbsup
All the close-ups you have posted show just how nice that car is.
Love it!!
