Post Info TOPIC: grinding noise
grinding noise
I tried to take my car out today. I have a grinding noise. Wasn't there last year. The only change I have made is swapping rear springs so the car sits lower and swapping the wheels. It is a duller grinding noise like dragging a cinder block on pavement, not a swqueal/squeak/sharp noise.
Here's what I have tried and found:
**quick starting and stopping, thinking that would shake off the "lot rot" from sitting over the winter plus the short drive in snow when we moved.
**loosen the brake shoes-they were stuck to the drums
**had a slightly stuck rf caliper, removed, pushed in piston, readjusted ft wheel bearing. This sounded like where it was originally coming from.
**rf backing plate was bent towards the rotor some, bent it back out of the way.
LF wheels sounds fine. No witness marks on inside of the wheels, plenty of clearance.
After all that and several test drives, not much seemed to change other than I can hear it cleaner now. Originally it seemed to be caused by dragging brakes, then it only seemed to happen with a hard swerving.
As I was driving through the neighborhood again, I think I came across something, maybe the driveshaft is hitting something? Seemed like when I hit bumps that forced the rear end up, I heard it, seemed to come from center of the car.
I haven't looked yet, but does this make any sense? My tranny sits a little higher than stock, do you suppose between bringing the rear axle center closer to the body that maybe it pushed just enough in on the yoke (shortened driveshaft btw) so that the yoke face is grinding on the tranny extension housing? I'll have to check tomorrow.
Any other ideas?
Hunk of rust/grunge got knocked loose from the wheel change, and is between the drum and backing plate??
Do you have a driveshaft safety loop ?
Forgot to add, the noise is spradic. Does not change with vehicle speed, not noticeable at idle.
Wheels have all been off, nothing grinding at the rotors, they spin freely and quietly.
I have a driveshaft loop, might possibly be hitting on the top side, there's tons of room below.
I'm definately leaning towards driveshaft yoke/trans snout area the more I think about it.
The amount of travel of the shaft in the trans is minimal but if it was made for the car with the rear that high it could be bottoming out. I'd look at the loop first, myself.
Are you running/using any kind of spacers for lift in your springs?
What have you used to achieve that tall stance? I like the look and want to raise my front end two to three inches.
Find a quiet parking lot or a side street and coast or get the noise to act up. Put it in neutral and shut off the engine and coast with the windows down to hear the noise. It actually works good in a parking lot thats empty because then you know your souroundings better in case you need to start the engine again. Obviously no engine means no P/S and maybe a few stops on the brake system until the pedal becomes hard to push, Unless its manual brakes that is. Ive had to do this on tons of customers cars over the years. Without the engine running, it can really open up your ears to where the noise is coming from.
Ive also coasted past a partner standing on the ground slow enough to communicate with him, like only a few MPH if that, walking speed perhaps, and gotten thier take on where its coming from. That is if the noise will do it that slow.
Ive seen several dried out u-joints make that kind of noise.
I would be thinking drive shaft too, but that should change with vehicle speed. Have you tried to put it into a lower gear when it's making the noise to see if the change in RPMS effect it? If you think it has to do with drive shaft angle maybe throw some weight in the trunk and see if that makes the sound change?
Perhaps look for marks on the drive shaft if it is hitting I would think there would be rub marks on it. Even in park car off move suspention up and down listen for noises. May not grind then but may clang and bang: )
I haven't gotten up to speed more than once (in a neighborhood mind you), to see any changes or more than a 1-2 gear change.
I like the idea of weighing the trunk down which should make it constant I bet, but I will be looking at the shaft for witness marks first. Assuming the driveshaft is hitting the loop, I can do some gravity fed adjustments with the floor jack.... shouldn't take much.
You'd see 'machining' marks on the driveshaft for sure. The 'not changing with vehicle speed' thing is odd. The first thing I thought was a brake dragging or one of those fat new tires rubbing a bit too- but you've checked all that out. Weird.
I would double check / replace your u-joints if nothing else pans out. Your new pinion angle maybe stressing them.
I had a 76 firebird that would make a noise occasionally more like a grinding sound with a loud pop sound followed by a vibration like out of balance tires. Checked the U-joints and seemed ok (but I was like 17, did not know what to look for). Needless to say, two weeks later with a car full of friends, passed a semi at 70 and BOOM! Rear U-joint caps busted apart and the drive shaft shifted in the yoke...talk about being in paint shaker Was able to pull over and stop and the drive shaft just fell out of the rear.
So any older used car I buy, I replace the u-joints as part of the maintenance procedure.
Definately will be looking at u-joints too, they were done with the driveshaft cut/rebalance back when I did the engine/tranny install.
I did look at the tire sidewalls right away too since they're tucked under and it seemed to come on with a swerving motion vs straight ahead. There aren't any cut/slice marks.
Check your routing of the emergency brake cabling setup also and see how close it is to anything moving...yoke to yoke and whether the wind could push anything into contact with your drivetrain.
Definately the top half of the loop. Since it was already on the highest set of holes, I took the top half out for now. I'll be working on a fix, but after a test drive, we're back in business again.
Home Depot has a "metal center" in the hardware aisle. Get a length of 1/4" x 1-1/2" (?) and make an "extension"... basically a square of metal with 4 holes.
OR
Just make a new upper loop with more Clarence, clearance.
-- Edited by John D on Saturday 12th of May 2012 08:16:50 PM
Here's part of my solution. Factory rubber mount instead of the Energy Suspension Polyurethane mount. I saved a good 1/2" I would bet:
What is you pinon angle with the change ? I would think 1/2 drop would change it.
Is the loop you have like this ?
http://www.jegs.com/i/Lakewood/620/18000/10002/-1?parentProductId=751248
I had to alter mine a little to work.
Yep, pretty much the same piece.
As for pinion angle, I haven't checked. I have Southside Machine upper and lower rear bars which have a drilled location for one of the brackets used. It would take some work to re-do it if it's too far off but I'll get to that eventually too.
