Post Info TOPIC: Could have been worse, need help locating steering column repair.
While working on carb with engine running car went into reverse.  Looks like maybe those stops in the column are worsen or missing.  Someone experienced with classic cars with column shifter.
banghead A Van Mattson helped me in the past; but can’t find his information.
-- Edited by jim larson on Monday 16th of May 2022 10:47:50 AM
Sorry to see that happened. I had that happen once with my Wagon
How did you solve the problem?  Or what was the problem, adjustment or column?
Call Auto City Classic and ask for him there.
Van Mattson
VanZ12@Comcast.net
1 (763) 350-0534
Auto City Classic: (763) 444-5880
Thanks for the help guys.  I talked to the steering specialist guy last night.  Evidently there  is suppose to be a spring inside the steering column that holds the shift lever up.  About 99% of the columns he sees have A broken spring.  Spring no where to be found.  He has developed a process to make something inside the column to fix the issue; but removal of column and disassembly is demanded.  Suspect  this is was modified after the 66 column as changes made in 67 and up.
He suggested: 1 make sure linkage is adjusted properly; 2 make sure the indents inside trans are not worn; 3 try to hook up some kind of spring on the firewall side of column to keep the shift part of the column rotating.   Be very careful when in P and engine running.
-- Edited by jim larson on Wednesday 18th of May 2022 08:33:58 AM
Van did some Column for us last year, did the spring "modification thing on two of them. . Also did two other columns, one 66 floor and 1 68 floor.
One column is in White elky.
Seems to work well.
I dont know. In my opinion since the 66 column lacks any safety collapse and the cost is already there to have your existing one repaired which means your probably going to want to replace those bearings too. I would spring the cost & replace with an Ididit.
It’s a 66 original tilt column.  One year only.  Different then BOP. But they will work.  Rebuilt ones if you can find  one run in the  neighborhood of $3000  plus.  Van said it’s a winters project.   Plan to live with it as is for the present unless some restorer to original wants it for a fair price.  Maybe Van this winter.  Good guy lives up in Blaine area.
Just checked the ididit site looks to be around $1500 for column, wiring, installation and linkage plus tax.
-- Edited by jim larson on Thursday 19th of May 2022 10:56:08 AM
-- Edited by jim larson on Thursday 19th of May 2022 10:57:31 AM
For now, if you need to have the engine running to work on stuff, chock 2 wheels, front and back, and put the trans in neutral.
 Thanks I was cocking wheels front and back plus E brake.  Good idea on N instead of P Since it happened in P. I think I also have to look at bending the lever a PO made as when the trans shifter is rotated the other end that goes into the linkage rod from the column does not rotate as it should, or into a locker linkabe kit.
