Post Info TOPIC: See where fixing a little spider web on a hood can lead you
IMG_0271.JPGWell you may as well paint the underside.
-- Edited by jim larson on Friday 28th of April 2017 04:49:13 PM
Slippery slope of this hobby.
Remember the factory left it satin black, actually just primer, lacquer at that!
Have fun!
And then starts the "as long as we are" disease.
 I don't understand, could you explain that theory...laughinglaughinglaughing
Have fun!
 I understand it was dipped in black lacquer,  then when they were painting hoods, fenders, trunks, and doors red for the day they painted a bunch, with overspray under the underside along the edges.  There were actually 5 coats of paint on the underside.  The original black lacquer, then a primer, then a red, then another primer, then black again.
If I remember right, the front sheetmetal was painted on a separate line.
Body shell with doors and trunk installed were painted as an assembly separate from front.
Was basically an empty body shell. Front sheetmetal was on some kid of brackets, color was blown over the edges on the fenders, almost no overspray on hood edges.
Doors, hinges, both trunk and doors were bare metal, body shell was bare metal all assembled.
1/4 extensions were set in place after caulking and priming body shell, installed and left loose after prime coats for topcoats.
Most often body primer was brown, depending on color, front sheetmetal black primer.
Sometimes body shell had two colors of primer, brown and black
If doors have never been off there is some caulking sealant on hinge surfaces, otherwise bare metal on mounting surface.
It has been a loooong time, but if I think most replacement sheetmetal came in black primer.
1/4 extensions bare or brown primer.
Most products were lacquer based, except for some pot metal pieces, they had some weird brown enamel product.
The brown body primers may also have been enamel based for adhesion to galvanized panels
This is on GM, whole different story on Ford, Chrysler.
Oh, and different plants had different processes!
Jim your under hood explanation is new to me.
I do not recall anything but lacquer primer, kind of a dull satin finish on the underside of hood panels.
I have a couple of original hoods, maybe we should do a research project.
Agree on the dipping, particularly on replacement parts.
Stayed up ALL night on a Thursday trying to smooth the primer out on several hoods fro prime and paint next day.
Took a really long time with 320 grit papers of the day (1968)
We are so blessed with our current materials.
http://www.chevelles.com/forums/12-body-shop/943353-67-underside-hood.html  I had looked at a post from Jeff Helms, who is kind of considered an expert of 65-67 chevelles, he has about 10 of them and most are original.
I kind of thought doors and trunk were painted along with hood and fenders; but you are correct as confirmed by another post I found from Jeff H indicates body was painted with door and trunk attached.  Now I will have to look at that 66 4 door parts car I have that I think never had the doors or trunk off.  Jeff seemed to think overspray on hoods varied according to plant.  I have  brown/red primer still on the inside of my car and also some appears to still exist on the underside the trunk upper panel that I cleaned.
I had my hood painted with just a little overspray near the edges.  I don't know if you are familiar with a guy from Chicago area  I think name is Rick Nelson that does restorations on chevelles and camera's.  He seems to indicated that the front sheet metal came with various amounts of gloss and color and when he does restorations, he uses a different gloss, etc for inner fenders, firewalls, hoods, etc.  Thanks for your comments.
On a side note, a guy here in Lake City started working in the Chevy garage in the early 60's, spent his whole life in body work.  He said they use to buff out the lacquer on all new cars before the customer picked them up.  I wonder if this was standard practice or Herron Chevrolet went the extra miles?
-- Edited by jim larson on Sunday 30th of April 2017 11:10:02 AM
Looks like Jeff and I agree?
Note: 64-65 had a completely different edge flange design.
In order to get color on the edge it requires rolling color over the corner, thus more o/spray on the underside.
66-67 had no edge flange, just a flat crimped hem flange, like a door edge.
They went back to the full flange in 68.
Firewalls tended to be a little glossy, once again depending on plant.
Core support and wheel housings were mostly that satiny primer type material.
Most bumper brackets and flange type brackets were in the satin black material.
Replacement fenders were edge painted (cut in) prior to us installing, 66-67 Chevelle hoods just bolted on and painted in place.
64-65 and 68 up were edge painted, bolted on and painted on car.
We painted very few items off car, unlike today.
Masking jambs, mouldings, and emblems was the order of the day.
Whole different (lower) level of quality to what we produce today.
This is a fun topic for me, brings back a lot of "back in the day" memories.
Thanks to you Jim,
Hood is finished and back on.  Now to work on getting the right stance.IMG_0275.JPG
Looks good Jim. Have you had your hood hinges rebuilt?
 No, they work fine.  They may have been rebuild prior to the paint in 94, there is suppose to be a guy on TC that is an expert of rebuilding hinges if you need that done.
 I just got mine back from Willie in VA. $210 with round trip shipping. www.hoodhingerepair.com
-- Edited by Lost in the 60s on Wednesday 3rd of May 2017 05:21:51 PM
