Post Info TOPIC: Winter project Updates-Let's hear them. CAC, GAC, and HAC included
CAC-Cars apart club
GAC-Garage apart club
HAC-House apart club
OK, so we're at the end of December and even though we haven't really had much of a winter yet, I know some people are already elbow deep into their projects. There's a few good threads already started about some projects too, so let's get some updates.
I'll start:
My rear disc brake conversion is done. I got stuff off an S-10. I'm aware there are kits available, but I'm a little mentally challenged and wanted to use GM and make it work. I did go with a new master/booster setup from Right Stuff, but the pieces are OEM equivalent. I added a Wilwood rear adjustable prop valve to help balance everything out. I learned to bend brake lines, and learned that fittings aren't ever tight enough and will need to do some frame re-painting in the spring from drippage. It was a good learning experience, I haven't really tested the brakes yet to see any improvement or not, just a once around the block before the ice started.IMG_0346.JPGIMG_0943.JPG
Once I get it all sorted out, I'll be writing it up for the newsletter
Looks great!
Keith - Rochester, MN
1970 El Camino SS 396 L78
'09 Viper SRT-10X Coupe
'09 Car Craft RSE Winner
10.76@133.73
190.0 mph Standing Mile
S-10s had rear disc? What years? What size rotor is it and will it fit the axle hub of a stock 10 bolt?  I like it.
thumbsup
My 99 s/10 4x4 has 4 wheel disc. Wouldn't know about anything newer, all I can afford.
Forest City, IA
Dan's right. It was around 99-04 or so.
The rotors aren't huge, just normal sized. I didn't measure. They should fit fine over a stock axle, I had to clearance my aftermarket axle ends down a little, but it was easy. You need some spacers to bring the caliper into alignment too, plus swapping out the master cylinder and proportioning valve.
