Post Info TOPIC: swapping power steering for manual.. whats involved?
Is this a simple box swap? or are there other components needed.. steering shaft? Pitman arm? etc...
I did the inverse on my '65, and the only item different was the pitman arm.
The GM steering boxes appear to all share the same physical mounting provisions, and coupling to the steering shaft.
In looking around there is a Saginaw 122 that has a 3/4"-36 spline input shaft. and a Saginaw 525 that has a 3/4 30 spline input.. I think the 525 is the replacement and you have to get a different rag joint to make it work on an older car.. Can anyone confirm this?
3/4-30 is what all the newer boxes have, and the rag joint does need to be changed.
For the conversion, an 80s Chevy 2WD truck ragjoint will work.
I think the steering arms on the spindles may be different.......manual to power and vise versa at least they where on my car when i went from manual steer drums to power steer disc.
Craig S - Shakopee Mn
 Yes, drum to disc is a different arm. If you already have disc, Tony, they should be OK. The bolt hole was smaller on the drum and could actually be drilled out to work on disc. I did that on my '66. I may have an OEM manual box here, if you want to mock it up.
