Post Info TOPIC: Anyone know where the drive shaft shops are?
I know about Proven Force, but they are like 2 hours north.  Does anyone know of any in the cities?
'Gear Lube'
I think Catco also does it.
What length do you need? I might have what you need.
I have one for a th350. I am putting one in for a 700r4. I think it is like 2" shorter than stock
'Gear Lube'
Catco in Roseville, west of the mall near the dealerships & lottery office. (This is the shop where they do the work, or where another Catco ships a driveshaft to).
I think there's a "Clutch & U-Joint" (or something like that) in Burnsville as well.
Wherever you go, I'd hold off until the driveline is in place with the final components. Call them and ask exactly how & what they want you to measure, then take it in for cutting.
Call Master Trans in Rosemount and ask where they get them done.
I found a Discount Transmission in Eagan....bing it for info.
There is Northern Engine in Hudson, WI. A Camaro Club member had a whole NEW shaft made for under $200...
I had one done at Clutch & U-joint in burnsville about 15 years ago, they've moved down near the Bville/Savage border on hwy 13.
The Rochester Catco location has changed names... Looks like they still do the same work, but with a different name on the door. Are the ones up there still the same, or did they get bought out?
Continental Engineering Chaska
http://cem-web.com/
When these shops balance the drive shaft, how many rpms do they spin the shaft at.  I had mine balanced at Catco in Rochester a few years back  and if I remember correctly, they could not rotate it all that fast?
Go with a 200-4R instead and you can use the same driveshaft, and you'll like the gear spacing better with a deeper overdrive too (I think it's 0.67 vs. 0.70)!  thumbsup
All you have to change is move the trans cross member to the most rearward holes.  All the rest is bolt in.
 x 2
200-4R are very rare to get. Also the trans guy I talked to said they are not as strong. I found that Proven Force moved to Maple Wood which is closer to me then they were before. They charge $100 for shortening, balance and paint. Thanks all for the help.
'Gear Lube'
Maple Grove, not Maplewood. They're actually a little farther from you now.
11071 93rd Avenue North Maple Grove, MN 55369
try:
Clutch & U - Joint Burnsville Inc
2401 Hwy 13 W
Burnsville, MN 55337
(952) 894-3100
Contributor
I know this is an old post but seeing if any of these places are still around? I'm in the south metro and will need a new drive shaft this spring/summer
Evan
Farmington
69 malibu formerly with 307...Now with 454
Proven Force is still around. I think the clutch and U-joint is still there off 13 near the Savage border.
Agreed with Bryan. Proven Force had my drive shaft back in like 2 days
'Gear Lube'
I have had a couple done at AA Driveline in Anoka, with no problems. aadriveline.com/
Contributor
Thanks guys. When my trans is done I'll have to visit those guys up at proven force.
Evan
Farmington
I am going to have to have one built for the DisAstre at some point.. good info to know..
PKB
Newbie
wheelco in newport just had one done 143 bucks including 2 u-joints
PKB wrote:
wheelco in Newport just had one done 143 bucks including 2 u-joints
 Was that all new components ? or shortened/balanced.
Have used Wheelco several times for balancing and confirming u-joint condition.
They have always been fair.
They do a LOT of big truck stuff.
Balanced, straightened, 2 u joints, sanded the whole shaft, and replaced yoke on pinion end, I think $180.
-- Edited by jim larson on Thursday 20th of April 2017 07:54:36 AM
