Post Info TOPIC: Photo of rear main bearing; how does it look?
Mitch suggested I post a few photo for opinions?  Thanks.
Looks like normal wear to me.  It looks just like the 396 that I worked on a couple of years ago.  Still has some of the wear indicator/protective coating left on the edges.  I'd put the new seal in and button it back up IMO.
I agree. It looks like there is still factory protective coating there (the milky, frosty area) so it looks good to me.
Button it up! If the cap bearing looks that good, the block 1/2 should be better. (The cap 1/2 takes the pounding). The only thing we can't see from the pics is the thrust surface - the area where that "disc" of metal presses against.
When you button it up, be sure to "align" the cap/thrust surfaces. Get the cap in place and in its registers. Torque to about 10-15 lbs. Using a big-azz prybar between the main webs and crank counterweight, pry the crankshaft rearward. Then pry it forward. Maintaining moderate forward pressure on the crankshaft, twist in about another 30 lbs. of torque on the main cap. Release the pressure and final torque the rear main cap.
What you've done is align the two thrust surfaces of the bearing to that "disc" of metal on the end of the crank. By just buttoning the cap down, the cap thrust surface could be fore or aft of the block bearing's thrust surface. All of the load would be borne by the rearmost bearing 1/2.
Don't forget a tiny dab of sillycone on the mating surfaces of the seal. You don't need a huge goober - just a dot (most will squeeze out when final torqued). Wipe the exposed ends of the rubber with some acetone or laquer thinner to get all the oil off of them, or it won't stick.
Bearings don' t have many miles on them and will be fine to re-use. I see the builder clocked the seal right with the block....no a leak waiting to happen.
Wouldn't hurt to have some assembly lube on hand for the build. If you want to wait till you have all the parts ready, we could assemble it all in one day and pre-prime it with a primer tool I have. You would have instant oil pressure at start up.
Thanks everyone.
John, now I know what a friend meant when he said I might not get the crank bearing back in the right place.
Mitch, I will get some pre assembly lube. Now all I have to do is get the correct head gaskets. I was thinking about the fel-pro 1037; but I see on the napa site, that they may need to be modified for pre 71 blocks. What does that mean?? Also thought about the 17046, 502SD, and the 8180PT2. All the sites have a disclaimer about the photos and photos of the same gasket are different on different sites. Some talk about irregular bore shapes other show kind of a circular shape.
Guess I don't know which to order.
