Post Info TOPIC: Tech Session Saturday, June 8th at 10 AM, Minneapolis
AK
Event Coordinator
Hey all. See below for details on next month's Tech Session (for my car).
Andrew Kraling's house
319 Vincent Ave N
Minneapolis, MN 55405
Main goal of the Tech Session is to trouble-shoot the ignition system and get the car running.
I suspect I burned out the coil when I was attempting to start the car after the fan/radiator fiasco last summer.
I have a pertronics ignition system (yes, I hear all of your MDI suggestions) along with a thrameflower coil. More info to come on those specifics.
Tooling in my shop for electrical consists of simple diagnostic and assembly (multimeter, single-probe circuit testers, soldering iron, crimper, stripper, cutter). I have a decent amount of electrical connectors, wire, etc.
However, there are various smaller projects if members want to split up (not in any specific order);
Dial-in linkage/carburetor/throttle body once ignition issue has been resolved
Install Radiator overflow tank/canister
Connect wiring/vacuum lines for cowl induction
Diagnose the wiring for the wiper blades/adjust blade arm position
Diagnose the volt meter (newly installed, but reading around 18)
Install neutral safety switch
There is some lower trim that can be reinstalled
Diagnose and eliminate the very annoying squeak
Install/fix chrome strip on front grill
Install passenger seat belt
Install new shifter handle
New bolt for the review mirror
Repair small vinyl tear in juke shelf
Few notes;
There is plenty of on-street parking in front of my house and the session will be held rain or shine.
I don't have a large workshop, but my garage is actually a carriage house with room for 2-3 separate work spaces.
Tools are limited to mainly hand tools. My large air compressor is not currently working (thanks harbor freight), but I might pick up a smaller one in the meantime.
There is outdoor seating for 12 and I"ll have additional tables and lawn chairs. We can spread out inside the house and carriage house to eat if it rains.
Food will be plenty; I'll have some pulled pork and beef for sandwiches and the club will provide water and beverages. Club will provide chips.
If you want to bring appetizers and of course, deserts, that will always be appreciated.
Theodore Wirth Parkway is very close to my house and might be an option for a few members to cruise down around Cedar and Calhoun Lakes.
More details to come. Thanks.
-- Edited by AK on Wednesday 5th of June 2019 06:50:58 AM
Andrew Kraling
Plymouth, MN
1971 Chevelle M22 468
If someone has a 3/8 drill with an angled head, preferably a 90 degree angle, please bring it. Need to drill a couple of hole in the pedal mounting plate.
Hankster
Columbus, MN
'60 VW Beetle
AK
Event Coordinator
A few updates;
Watching the weather and looking ok for rain as of now. I don't have A/C in the garage, but will have in the house if anyone needs to cool off.
Kids and significant others are more than welcome.
Come and go as you are able and no obligation to turn any wrenches.
Can someone bring a small air compressor?
Hank and I discussed food - see posting above.
Parts - I have the diagnostic diagrams from Pertronix for the Ignitor I and Flamethrower coil to trouble-shoot my existing setup.
Summit is delivering a plug and play Ignitor III and flamethrower III system - complete with distributor.
I have a majority of the other parts and will be posting a few more needs as I can't locate random screws / hardware for;
Driver side mirror (two interior screws for mirror position bracket) - I have one, but need one more. I'll post images in the next day or so.
Mounting hardware for the chrome strip on the lower body below the passenger and driver doors
I need a single piece of chrome stripping over the driver door
Screws to mount kick panels
Andrew Kraling
Plymouth, MN
I won't be able to make this one. I was looking forward to seeing your house and carriage house. I have a HEI distributor if your new one does not arrive. If someone would like to pick it up.
I have a spare HEI one I was planning on bringing
Hankster
Columbus, MN
'60 VW Beetle
AK
Event Coordinator
Below are images of the hardware/trim pieces I need. I realize some of these are available in an entire kit, but I only need one/few pieces of each so hopefully someone has a spare. I also looked at AMKproducts and could not located the hardware for the body trim.
-- Edited by AK on Thursday 6th of June 2019 06:33:24 AM
Andrew Kraling
Plymouth, MN
AK
Event Coordinator
Yesterday I realized the ignitor system states to not use solid core spark plug wires. I'm wondering if that is part of my issue. I'll look further into my MSD wires and call Pertronix if needed.
Andrew Kraling
Plymouth, MN
AK
Event Coordinator
Before images of door panel and interior.
Andrew Kraling
Plymouth, MN
AK
Event Coordinator
Before images of throttle linkage and cowl induction.
More than likely I'm missing a few parts for the cowl induction.
-- Edited by AK on Thursday 6th of June 2019 06:51:56 AM
Andrew Kraling
Plymouth, MN
Sorry I wil not be able to make it to your place Andrew.
Having minor surrgury tomorow afternoon.
AK
Event Coordinator
No problems, Bruce.
Hope you have a productive surgery and fast recovery.
Andrew Kraling
Plymouth, MN
Hank, I have an angle drill so I will bring it along.
Andrew, I have misc screws of various sizes I will bring along. They will not be GM hardware but maybe we can get some things hung on the car.thumbsup
I believe I’m bringing a dessert of some kind, Jenny was in the rhubarb patch this morning.
AK
Event Coordinator
Okay so I caved and dropped an air conditioning window unit in the carriage house we have AC in the main house as well very welcome to take a break
Andrew Kraling
Plymouth, MN
AK
Event Coordinator
Does anyone know where I can get the clip for the back of the driver mirror adjustments outside of buying a complete replacement?
Andrew Kraling
Plymouth, MN
Sorry Andrew, not gonna make it today. Just too far behind with everything after spending umpteen hours chasing paint and parts for 2 cars this week.
AK
Event Coordinator
No worries Mitch
can't wait to see the new paint job
We'll let you know how it goes
Andrew Kraling
Plymouth, MN
Good to hear you got it running again !!
AK
Event Coordinator
A big thanks to everyone that came over yesterday to help me diagnose the timing issue with my car.
A special thanks to those of you that brought the timing gun, air compressor, a 90-degree drill along with all of your other tools and especially your knowledge. Appreciate your patience with my battery issue.
It's amazing to see the progress on this car over the last year and a half. I learn so much at every tech session and at every Club event. Without this club I would be in the same position as I was a year-and-a-half ago.
I took the car out last night twice and again twice today with the family. It fires up right away and drives well. It's nice to have a seat belt for the wife! I'll have to diagnose that annoying little squeak 🐁.
I look forward to seeing you all the next event.
Andrew Kraling
Plymouth, MN
AK
Event Coordinator
A few pics from the work day and after cruise.
Andrew Kraling
Plymouth, MN
AK
Event Coordinator
Andrew Kraling
Plymouth, MN
Sorry I couldn't make it.  Too many house projects this weekend I've neglected when working on the Malibu...
Glad to see the club spirit alive and well with everyone pitching in, and Andrew you have joined the group that has moved their car along to the next stage, and I'm sure at some point you will be the one providing help to another member!  It's part of the club 'thing'. thumbsup
Good to see you got some of the issues sorted out and where able to take the family for a ride!
-- Edited by BLyke on Monday 10th of June 2019 11:56:22 AM
AK
Event Coordinator
I never thought it would be the distributor/ timing out of sinc.
A new set of plugs were required... I should have checked those beforehand.
Many thanks for the carb help.
Andrew Kraling
Plymouth, MN
Sorry for not making it. Wife and son were out of town this weekend & since my shop is the and has been the project for several months of weekends, took advantage & kept at it again this weekend too.
AK
Event Coordinator
Quick update on my Chevelle. I've started it at least 30 times. It has been running really well. Had to slightly increase the throttle position.
I dropped in a new battery and reassembled the door panel working on some other small projects.
I was able to take my niece, nephew and daughter to back to the 50s and on many fun cruises with the wife.
it's such a blast to have that car running again
thanks again for everyone's help and certainly looking forward to paying it back/forward.
Andrew Kraling
Plymouth, MN
