Post Info TOPIC: Engine Mount
Engine Mount
Very creative and resourceful.
I saw that on another forum a while ago and people were going nuts about how those wrenches weren't strong enough and were going to bend, break, etc. Sheese, a crescent wrench is malleable iron and will probably be stronger than any stamped plate the factory used...rolleyes
See some of that kind of "outside the box" engineering on the rat rods at BTTF.
My late-30s built midget racecar has the steering box mounted with connecting rods.
There's a guy on the Factory Five Forum who seems to have earned "Zeus" status over there... all bow down to the god of roadster builds, etc.
(His build(s) are incredibly documented and gorgeous, but a bit too much "engineer"... not horse-sense)
The coupe version of the car has a driveshaft every bit of 3-inches long - it's basically two U-joints welded back to back. Take a look at the picture.
Do you think SIX, 5/16 bolts were necessary to hold the driveshaft loop in place?... let alone NEEDING a driveshaft loop?
That's a clever idea. I'm also curious about the strength of those wrenches.
But it sure is pretty.
