Post Info TOPIC: Center console and staple shifter
Any idea what a complete center console and staple shifter would go for...used? Reproduction would be fine.
Saw one installed in a Vega and I like it..
Shiftworks makes a 4 speed conversion kit for the staple shifter.. and also a ratchet detent plate to upgrade it.....
www.shiftworks.com/chevelle-68-72.htm
I've used the Shiftworks OD kit a couple of times, and it works great.
Most used consoles go for around $250-350 depending on condition.  The used shifters go for anywhere from $50 to $100 depending on condition.
I think you can buy all new stuff from NPD or SS396 for around $500?
Depending on the shape of your floor some shifters may fit better than others. Camaro/Nova, Chevelle/Monte Carlo, and Impalas all had different bases on them... Camaro/Nova style seem to be the easiest to find used originals at swap meets.
The guy said it took quit a bit of trimming... Does this look Chevelle to you?
He saved the original E-Brake location.
The console is Chevelle, not sure about the shifter.
Have you looked at a 68-72 nova console setup. Can use the horseshoe shifter but much shorter console so your e-brake would not be affected.
I think I like the chevelle one.. Im used to an armrest of sorts..
The Camaro shifters have a flat base, the Chevelle ones have a stairstep to them because of the floor. Not sure if the nova is same as the Camaro or not.
I would definitely go with a positive detent modification if I went to a staple shifter again. I found it too easy to over shift, though with the 4 speed auto, the gates were shorter too.
This guy makes new staple shifters and can do flat consoles too: www.kilduffmachine.com/
Looks like Kilduff has your shifter...laughing
Exterminator Shifter
There's always.....
-- Edited by bowtie on Saturday 27th of February 2016 10:06:24 AM
