Post Info TOPIC: SOLD: Viper T-56 6-speed Retro Fit Transmission Kit
D&D Performance Viper spec. T56 6-speed transmission. Bolts to standard Muncie style GM bellhousing and uses stock mechanical clutch linkage. 26-spline input shaft, same as M22. Custom tail housing accepts speedo gear (not included) for cable driven speedos. Trans is upgraded with carbon fiber blocker rings and steel shift forks.
Direct bolt in setup for Big Block or Small Block in a 116" wheel base A-Body.  Driveshaft can be sent back to Denny's to be shortened.
Centerforce 11" Dual Friction clutch.
Lakewood 15000 Steel Safety Bellhousing.
Denny's 3" Nitrous Ready Driveshaft with Spicer 1350 U-joints and slip yoke.
Moser forged steel 1350 pinion yoke.
'68-'72 stock crossmember with modified trans mount.
Steeda Triax Billet short throw shifter.
This was all installed in my '70 El Camino. Everything is in excellent shape and works flawlessly.
$3500.  Will separate.
More info:
http://www.superchevy.com/how-to/148-0305-t56-six-speed-transmission/
-- Edited by Back in Black on Saturday 28th of February 2015 06:36:38 PM
-- Edited by Back in Black on Saturday 28th of February 2015 06:48:37 PM
-- Edited by Back in Black on Tuesday 10th of March 2015 06:27:59 PM
Keith - Rochester, MN
1970 El Camino SS 396 L78
'09 Viper SRT-10X Coupe
'09 Car Craft RSE Winner
10.76@133.73
190.0 mph Standing Mile
RE: Viper T-56 6-speed Retro Fit Transmission Kit
Interesting. What are you doing to the Elky?
Returning it to it's as left from the factory configuration.  So all the aftermarket performance parts are for sale.  I'm keeping the 496 short block for now but heads, fuel injection system, valve train, cooling system, brakes, power steering, wheels, tires, etc...all going.
10.76@133.73
Dang, wish I had that kind of coin available. That would be so nice in one of my Chevelle's...hyper
Keith. Im interested in the fuel injection system, heads and maybe even the brakes. I remember they were Wilwoods, which Wilwood kit was that and what size are they again? Would they be able to fit inside a 17 inch wheel?
Let us know when the stuff comes available.
 Everything is available now.  Anyone seriously interested can send me a c-note and I'd be happy to hold on to it for a while.  Storage space isn't an issue.
10.76@133.73
Front: 140-6743D
Rear: 140-6293D
12" rotors.  6 piston front calipers, 4 piston rear. Yes they will fit inside 17" wheels.
10.76@133.73
Contributor
i'm interested Dave 651-777-3022
Updated with more info and parts.
10.76@133.73
