Post Info TOPIC: 70-72 Heater and AC box-engine side of firewall
On the 70-72, are the heater core tubes that come out of the firewall moved for the AC cars vs the heat-only cars? I'm looking to remove the AC firewall stuff (engine side) from my car. I thought learned that the heater cores came out in different places, if that's true then I can't use a regular heater/blower motor case. I want to keep the heater so I can't just use one of the block off plates that's totally flat.
What about something like this?
http://www.opgi.com/chevelle/1972/cooling-heating/heaters/CH27810/
We should be able to fabricate an adaptor plate to mount the standard heater on the firewall while blocking the A/C opening. My GTO is sitting here with a bare firewall and the heater box is on the shelf for reference. Once you pull your A/C system off, you can get a dimension for the overall size of the plate.
I just remembered I have a '70-72 A/C box sitting on another shelf. I could trace that on a sheet of steel and cut to size and drill for original mounting studs and standard heater box.
-- Edited by Lost in the 60s on Monday 9th of December 2013 05:08:50 PM
thanks guys. I think I prefer the molded box, only for the factory look. I did think of making something along the lines of what you're describing Mitch, but I think it will look a little too out of place for what I have in mind.
A flat plate wouldn't work, because there's no "duct" for the fan to blow air through the heater core.
Yup, that's what I want to stay away from. I had thought about folding up a simple \__/ tunnel and mating it to a blower motor base, but in the end it will take way more than I want to do to make it look nice.
The link I posted says they are plastic or fiberglass depending on application, but it doesn't say which the Chevelle one is made from.  It would allow you to keep your heater.
I forgot who the vendor was it was 14 years ago.. But I have the fiberglass replacement cover on my 72.. worked great
Probably American Graffiti?
Do you have a picture as installed Tony?
I just saw this Bryan so I went out and snapped a couple of pictures..
Thanks, that's going to be my first winter project.
