Post Info TOPIC: Instrument Lighting
Instrument Lighting
60 and 70 ish instrument lighting was provided by a 194 bulb. If I remember correctly there is also a 184 bulb which one is brighter?
Go with e new LED replacement
'Gear Lube'
194 = 3.8w, 2cp
184 = 3.4w, 1cp
168 = 4.9w, 3cp
All are the same T3-1/4 bayonet base, and physical size difference isn't enough to worry about.
194 = 3.8w, 2cp
184 = 3.4w, 1cp
168 = 4.9w, 3cp
 What about tempurature, John ?? The 194's get hot enough as it is. Would the 168 start melting plastic holders ??
I agree with Tom. If you can find an LED replacement, go with that.
Heat is a problem, especially when GM changed from stamped tin to plastic housings. A 168 would probably be too much.
I haven't kept up with the LED replacement bulbs, but I've heard/read they have improved the "dim-ability". Problem with an LED is they have a specific voltage range where they work - they are a solid state device. Too low they simply won't turn on. Too high and they'll fry. Incandescent bulbs are analog and infinitely "dim-able".
