Post Info TOPIC: RPM Calculator
RPM Calculator
Mitch wrote:
  Time for that 200r4 with a lock-up converter to lower the rpm's....stirpot
I am about ready to pull the trigger on the 200 4R (once I get this oil sucking POS rebuilt next month) although the tranny builder reccommends against the lock-up and talking to Pushrod, he has actually disconnected his and says it operates a lot smoother without it.  Yes-no-maybe?  headscratch
-- Edited by Jon H on Sunday 12th of August 2012 01:20:01 PM
I was looking at several rpm calculators and they seem to vary some, but not drastically.
The real question is:  I have 3.55 gears with 275x60x15 rear tires.  The tire calculator shows these to be 28" diamater.  Under weight they are 26.5".
Which diamater do I use?  headscratch
Are there other factors involved?  headscratch
The calculators show at 70 mph with 3.55 gears and a 28" tire an rpm of 3062 and a with 26.5" tire an rpm of 3235.  My tach is showing 3500.  Why the difference, assuming my tach is accurate? headscratch
There's no way that tire is deflecting 1.5 inches under load. That's half the sidewall height. It would overheat and blow out.
I ran some variations on ratio and tire height too and I'm thinking your tach is off, since none of the calcs match 3500 rpm...dunno
Converter slip is usually over 10%, so your tach is probably right on.
I'd go with what the actual tire height is with weight on it.
On a remeasure I am getting 27.25.  Originally I only measured center cap to floor and doubled it which I think threw it off.  I am running a 7" wheel   instead of 8", would that reduce the diameter a little?
The .75 lower height is the loaded diameter, which is accurate. A narrower wheel can make a tire taller due to crowning, not lower.
I forgot about converter slippage too. Derek is probably right about the tach. It may still have an error percentage coupled with converter slip which will get you where you are.
John at Master Trans gutted the electronics in my 200-4R and made it pressure driven overdrive only.  He used an 11" 2400 rpm stall converter, and it worked great around town or on the highway with both the 4.10's and 3.42 gears that I ended up with.  It probably lost a couple hundred rpm locking up on the highway this way vs. an electronic lockup, but it still only ran 2500 at 70 mph with a 26" tall tire.  With your taller tire, it would probably run less than 2500 at 70 mph.
This setup worked great around town, and it would shift into OD a 40 mph, but upshift into 3rd as soon as I touched the throttle.  Somehow I lucked out on the TV cable/carb linkage adjustment, and it worked great.  I'd recommend this setup.  Give John at Master Trans a call in Rosemount if you have questions on how he set it up.
 He is the one that reccommended the non-lock-up.
GM is now going to overhaul the current engine to fix the issue ??
 I thought you had heard, yup.  Happy days ahead, I hope.
