Post Info TOPIC: fixed my air cleaner issue
My air cleaner was having fitment problems with the serp belt swap. The waterneck and hose sat too high for the filter to nicely sit on the throttle body so I had it cinched tightly on there but akwardly and it was pinching the bottom pretty bad.
While out in the garage today, I found a piece I had bought to mock up a ram air setup down the road. It's a factory air horn for a Camaro or Vette (I forget) and was used between the TB and the factory air cleaner box that was mounted on the core support. I put that on the TB and saw that I could fit a shorter round filter on the end, maybe just having to make a cap on the front face. A little light bulb went off and I shoved the K&N unit I had over the round end. It sat in kinda far and would have blocked airflow, so I cut it off and tightened it down. bad cell phone pics, but it does the job I needed and looks decent. It rests over the radiator hose and is plenty far from the belt.
-- Edited by bowtie on Saturday 25th of September 2010 04:45:06 PM
Nice job. Innovation wins again!
Things that make you go hmmmm.... maybe if I try..??
FWIW, the TPI throttle-bodies have the same size oval opening as the LT1 throttle bodies, so an elbow off a Camaro would fit... looks like your alternator would be in the way to route it into the front left corner though.
Derek- yeah, I was thinking about going that way before I did the serp swap. The thing holding me back was the $75 or so price tag for that elbow.
As it is, I don't think I can make an effective cold air intake for the filter to be somewhere else either-between the belt and hose, the only way to go is down and it would have to be a pretty small tube. I might opt for a better spacer than this plastic corrugated thing I have now, but that's not a necessity.
In that case, That oval is the same circumference as a 4" dia circle, so if you can find a scrap of 4" alum or S.S. tube, you can just squish it down into an oval.
