I have a 2005 GMC Sierra and the climate control numbers are stopping working one at a time first 4 went out then 3-2-1 my fan only works on high now. Any suggestions?
If you see this man the best course of action to take is... RUN!!!
Sounds like a blower motor resistor. I've had several of them go out in GM products. Normal symptoms is only the high speed works. They run about $25 and are usually mounted near the fan on the passenger floor.
And you were right SteveS only it had to be the $60 one not the $25 one..... But at least the Prego wife will ride with me now that she has all of her fan speed selections LOL (four bolt hole vs two bolt hole)
