Post Info TOPIC: Hyrdratech Hydroboost Hydraulic Brake Assist
For '64-'72 A-Body vehicles.  Complete plug and play system if you have power steering.  $525.00
Keith - Rochester, MN
1970 El Camino SS 396 L78
'09 Viper SRT-10X Coupe
'09 Car Craft RSE Winner
10.76@133.73
190.0 mph Standing Mile
For anyone that has thought about this, I would suggest going for it. I did it and the braking is amazing. I can give you some tips through my trial and errors. You can use your stock reservoir. One thing I don't see here is that your power steering pump reservoir will need to have a return. You can easily get one of these from a chev truck. You can google it, or pull yours and weld one on. I bought the chevy truck one. It is one from the 90's F250 from Oreilys. Was a direct swap with my pump.
'Gear Lube'
 I admit I'm not a power steering expert but I didn't have to do any welding on my pump reservoir.  Don't they all have a low pressure return line?  Mine did.  The rubber line from the Hydroboost unit tees into the normal return line.
This is a plug and play system.  All fittings and adapters are included.
-- Edited by Back in Black on Monday 14th of September 2015 09:01:32 PM
10.76@133.73
Yeah, I they all have a return so you just have to T into the hose somewhere.
agreed thanks for clarifying
-- Edited by gearlube on Monday 14th of September 2015 09:57:22 PM
'Gear Lube'
Bump......$500
10.76@133.73
