Post Info TOPIC: LS Motors what is the best motor to use
I'm going to do a swap, the 5.3 is cheaper the 5.7 are expensive. 6.0 and 6.2 are high also but i'm thinking it's better to have more cubes if you want more power right?? is there a big difference between the 4l80 and the 6l80 ??
Roger Blad Burnsville, MN
I think the LQ4 6.0 is one of the more popular LS engines.  Here's a guy in Eagan that has a couple for sale for $500 (would likely need to be opened up to check the internal condition): http://minneapolis.craigslist.org/dak/pts/4419679317.html
Here's a complete one for $1100 with 115K miles that might be o.k.: http://minneapolis.craigslist.org/ank/pts/4410545308.html
And another for $1200 with 124K miles: http://minneapolis.craigslist.org/ank/pts/4387508855.html
AAA Auto Salvage in Rosemount will sell the LS cores too, but you need to buy all the accessories for it separately.
The least expensive route is the iron block 5.3 from a truck.  But as I've learned when researching this, the cheap part is the engine itself.  The costs add up FAST after that; Wire harness, ECU, oil pan, engine mounts, injection system from a Corvette, Camaro, Firebird, etc. since the truck system is typically too tall to fit under the hood, exhaust headers/manifolds, and all the misc. metric to SAE adaptors needed.  I'm guessing the engine swap alone can run from $3K-$5K depending on how much of the original stuff you are able to use, and how detailed you get into the install.  Throw in another $2500-$3500 for a 4L60E, and you are not on the cheap path anymore.
The other thing I understand is that the LS engines torque band doesn't kick in until 3K RPM, so expect a high winding engine to get into the power band vs. the BBC you have now with torque from 1500 RPM and up.  That's how the 5.3 in my '03 GMC works.
I'm sure Dashboard has more insight having done a ton of research on this for his Buick swap, and Steve S. has done this as well.
You could always find something like an entire truck to get everything off it. That Silverado Derek has for sale, if he still has it, would be a good candidate to get everything to swap into another vehicle.
I think you need to decide what you want to do with your car after the LS conversion. Do you want the 11 second rubber burning go sideways at 30mph, screaming rocket on a cheerio stick that Steve built? Or do you want a car that will make square corners out of round ones like Derek is putting together? Or would you prefer the mild mannered, very reliable, gets great gas mileage if you can keep your foot out of it, little old lady car I put together with a lot of help from several others? Any of the LS engines from the 5.3 to the 6.0 can easily make over 800hp if you have the money to throw at them.
Before you decide which engine is the best for your application, you need to do a lot of research, and I mean a lot. ls1tech.com is a source for information, however like any internet source be prepared for both good and completely erroneous information from posters. There are several books on the subject; most of the ones I read where more like cover to cover infomercials.
I started my research 18 months before I actually started the Buick conversion project. I was lucky to score an aluminum block 5.3 L33 HO engine with only 65,000 miles on it. Once I actually started the conversion however, almost all the research I had done over the last 18 months went right out the window.
I would suggest you get to the next club meeting that Steve or Derek will be at and spend some time under the hood with them.
It can be pricy depending on what you want as a finish product; I know I’ll never add up the receipts from my project. I still have several little things to complete on mine but I’m pleased with it and it’s a lot of fun to drive.
My motor in my 57 is a 2008 6.0 3/4 ton truck motor. 352 hp stock. I bought the motor with 8k miles on it, computer, starter, water pump, flex plate, exhaust manifolds, alternator, and power steering pump for about $2300 If I remember correctly? I put in a $ 800 Mast cam kit for that motor, then had it re tuned. So $3100 for the motor plus the re tune. Thats the part that get expensive unless you know somebody that has the software or you can send the computer to for reflash. I did buy a aftermarket long harness so I could hide the wires better and mount the comp under the seat. I attached the dyno sheet. The cam is fairly mellow and look at the torque curve.
Brad
Nice numbers Brad and it will get nice gas mileage also. I think mine is about 320hp and 340 torque. I'm looking forward top see what Steve's does if he runs it on the dyno during the May meeting.
I agree with what's been said, it depends on what you want.  If you're not concerned about weight I would look at an iron 5.3 or 6.0. They will be the cheapest.  Try to get the transmission, accessories, computer and harness with it.
Brad's numbers are very impressive, amazing what you can get with just a cam swap.
Those engines can take a beating too. A friend has a stock bottom end 6.0 that's held up to over 700 turbo'd horsepower. Another friend has a redline of 7700 rpm.
Find a running example, take everything with it including the harness, all sensors, ECM, trans, etc (or buy a wreck so you don't miss anything). Tuning is more readily available now too. If I hadn't already gone the way I did with mine, I'd be all over an LS engine.
