Post Info TOPIC: 70' tank, perf. fuel/ air delivery parts
Spring Cleaning:
All items are also on CL. Items on NCC forum are discounted from the CL price.
1970 Chevelle gas tank. Used 2 seasons looks like new, sender not included, $60.
Holley 4150 750 cfm vac secondary carb. This is a list # 3310 4160 converted to a 4150 style carb with the rear metering plate. Rebuilt over the winter and has about 100 miles on it this year. Ran great when pulled last week $140
Holley fuel pressure regulator with carb feeds, base plate, -8 inlet and gauge. Comes with all fittings to connect to carb. This is a $120 setup new. Only about 100 miles on this. $70
K&N 14x4” Filter with Moroso cover and drop base. Used 1 season. $30
Phenolic square bore carb spacer $20
Trick Flow Fuel Pump. 140 gph, 14 psi max. Used 2 seasons and worked great when pulled last week. Used for carb setup. $60
Russell 40 Micron Fuel Filter, -8 inlet/ oultlet. 100 miles on new mesh $20
Aeroquip socketless hose, -8 diameter, about 15 feet in length (ran the length of a Chevelle). Used 1 season. $20
LS Gen III/ IV Electric fan controller. Used 1 season. $20
4150 Fuel log (Attahched to Regulator below), -8 inlet/ outlet $20
Barry Grant Return Style Regulator (For Carb) $30
-- Edited by seagrams72 on Saturday 5th of May 2012 08:45:23 AM
Andy
Southern Suburbs
RE: Cowl hood, tank, perf. fuel/ air delivery parts
Better pic of hood? Is it solely pin-on or is it only pins in the front?
Bryan, here are a few on the car shots. Also this is a hinged, front pin hood. It will bolt to your factory hinges, and pin in the front.
Andy
Southern Suburbs
Does the hood have more clearance then a stock metal SS hood ?
I would say yes to overall area, because there is no structure like in a metal hood. As far as height I would say I'm not sure and it is probably close to being the same height.
Andy
Southern Suburbs
RE: 70' tank, perf. fuel/ air delivery parts
A few items gone.
Andy
Southern Suburbs
