Post Info TOPIC: Here's the brunt of what I'm bringing to the Bowtie Brunch on Sat
Misc tools including soldering gun, B&D jig Saw, old metal body B&D jitterbug sander
90's Camaro spoilers-both pedestal and full lid styles
70-73 Camaro bucket seats from my Chevelle
late model 5.7 water pump-NEW
all the SBC v-belt stuff from my car: ps pump, alt, w/pump, ac comp ald all brackets
700R4 inspection cover
502 crate engine valve covers (black style)
69 Camaro wheel well moulding set (Goodmark)
72-75 Camaro window moulding
chrome BBC v/covers (new in box)
SBC short chrome V/covers (new GM Perf)
SBC tall v/covers (new GM Perf)
10 chrome air cleaner NEW
TBI style TV cable
cone style air filter for EFI
67-69 Camaro upper rear window mldg
70-72 Chevelle console seat belt cups
70-72 CHevelle rr suspension upr to lower front braces
braided metal hose covering kits
If you want dibs, let me know ASAP
Dibs on the set belt cups.  Bryan, PM me how much you want.  Thanks.
Here's my list:
69 12-bolt, dated B49, coded for 3.73 posi
69 factory tach 5500 redline + gauges & clock
69 black door panels and rear interior panels
69 black arm rests front and rear
69-72 BB/4spd steering column
69-72 F41 rear sway bar + factory boxed lowers
68-72 12-bolt upper arms
70 SS steering wheel
68 SS steering wheel center
(set of 4) 245/60/14 BFGoodrich Radial T/A tires
(2) Grant steering wheels w/ GM adapters
(2) 14" air cleaners
SBC cast alum valve covers
BBC cast alum valve covers
BBC alum short water pump
SBC Edelbrock Performer intake
SBC Weiand Torker intake (old single-plane)
Sun Pro tach
Autogage tach
not on the truck yet, but might also be coming if I get ambitious:
Shiftworks automatic/OVERDRIVE conversion for 68-72 console/staple shifter. (hey Stan, you need this!!!)
68-72 reproduction center console (black) w/ automatic top plate
68-72 reproduction staple shifter w/ cable
69 Camaro staple shifter
FREEBIES:
69 air conditioning (all the crap that goes under the dash... already gave the rest of it to Jamie)
67 standard speedometer cluster...
The 5.7 water pump is that for a serpentine setup? I picked up a standard for the new engine and had that on for Dyno time.
The 5.7 pump is part number 88894341 (google it), comes on crate engines, which is how I got this one-It's a new takeoff, best I can remeber it's never been used only bolted on.
I will check tomorrow if it's also a factory unit and on what.
Derek-dibs on a Grand wheel adapter Got a new wheel for x-mas and haven't gotten an adapter yet.
Here's my list:
 Derek, PM about the rear sway bar and boxed lowers as well as the Shiftworks kit and let me know how much you want.  Thanks.
Derek,
If Stan does not take the Shiftworks kit.  I would be interested.  Let me know.
Loren
Bryan,
Any of those valve covers, center bolt style for the Vortec heads?
-- Edited by 69SSConv on Sunday 16th of January 2011 08:56:08 PM
nope, sorry
69SSConv wrote:
Derek,
Loren
Loren, I'm passing on the Shiftworks kit since the lens has green lettering instead of the white that I need for a '72.  The green should be correct for your '69.
Thanks Stan, I will PM Derek.
Here is what I can bring
2 Taurus electric fans (one with oem relay box)
1 Windstar electric fan with relay oem box
MDS 6a ignition box
Edelbrock sure Seat 5767 springs
comp 7812-16 pushrods
May also have center bolt valve covers (OEM) - gotta check first
Will bring if interest:
65 10 bolt rear (open 3.08) (if Bungy L-76 is interested)
Serpentine belts setup if any interested I will bring
90's? 5.7 block with 1 piece rear seal, crank, flexplate, tin (oil pan & timing cover), and a box full of rods and pistons. This was from two engines but 1 block was bad.
John,
I would be interested in the comp 7812-16 pushrods .  I was going to purchase for my 350 rebuild.
Loren
I am bringing a new set of BBC Power Steering brackets, this is the 3 piece set if anyone is interested.
Not a big demand for a 72, 7/8" fwd sway bar (68-72 I think) but if someone wants one thay can have it free.
Just say the word and I'll bring it.
Looking for an old 4 speed shift kit for a Muncie, something you might just throw in the trash. Going to be used as garage art, does not need to be fuctional.
John,
Let me know if you have a set of the center bolt valve covers?  Need a set for my 350 rebuild as well.
Loren
John, are those valve springs new or used? I may be interested in them.
John (enganeer) Bring the 10 bolt rear, I'll take it.
Also if anyone has a posi carrier for an 8.2 ten bolt, I'd be interested in that as well.
Loren - the valve covers are center bolt. I did not see the bolts, not sure if they are special.
67ss - The springs are unused.
Bungy - Maybe be able to bring the axle. It's buried and there is alot of deep snow to get past to the truck.
PM me and let me know how much you want for the springs.
Thanks
John,
I would be interested in the pushrods and the valve covers.  Sent you a PM.
Loren
Dave- My 5.7L waterpump is also OEM for 82-87 TPI engine or 83-88 Crapice (among other stuff)
Also have:
new set of 4.3 "W" engine plug wires
98-02 hi beam lamp and connector
Oh yeah, I also have a single BBC pushrod for a 67-74 427 or 454 that is 8-7/32 o.l. new in package
i'm just saying...............
I have a brand new in the box. 1000Lb rated 4 wheel engine stand available that I can bring for anyone thats intrested.
I'll take the water pump,
Looking for an engine dolly that sits low to the ground with casters
Here are a couple things I will be bringing if anyone has interest.
1. Set of 993 casting SBC cylinder heads. Totally stock should be gone through before using.
2. Take out roller cam from a 383 crate motor. Part number 14097395.
I have a few parts I would bring if anyone is interested:
-A set of Backup lenses for a 72'
-White inner door panels for a 70-72', power mirror car (sorry Mitch I don't think I will use the set I bought from you)
-A/C Control head (70-72'), not sure what other years this works with.
-Full p/s setup. (pump, gear box, and brackets for small block car, no pitman)
-Lincoln LS seats I have listed in Craigslist section of this forum.
-Firewall a/c/ heat delete for an a/c car (can modify to fit a heat only car too).
I may not bring much since I am not too much of a part collector and usually only buy stuff I need, but if anyone has any of these, consider them sold on Saturday (All would fit 72' 2 dr coupe):
-Driver door fuzzie (not ripped like mine)
-Cowl grilles for an a/c car (go in firewall)
-Heat only control head (I have an a/c one for trade if interested)
-Any defog or heat vents that go in the dash. (only diffusor or vent I need is the one above the dash heat/ a/c control head and defog vents, also tubing for the side/ center vents and defog.
-Rear window chrome moulding.
Thank you to Derek who is bringing parts and Mitch and Stan who I have already purchased from.
I can also finally sign-up again and pay my dues on Saturday!
-- Edited by seagrams72 on Thursday 20th of January 2011 05:41:26 PM
Andy
Southern Suburbs
Here's  few things I'm planning on bringing too.
SBC Bowtie Spark Plug Wire Looms : Link
SBC Taylor 8mm Spiro Pro Plug Wires : Link
MSD Hei Advance Kit : Link
Partial Set of '72 Monte Black seat Belts
23,000 BTU Kerosene Heater : Link
I also have a rebuilt alternator (original GM) and NEW q-jet that I am bringing for someone, plus a brand new '90s Impala SS master (LH) window switch.
I'm bringing FREE magazines from the past couple of years for others to enjoy.  Take one, take them all.  Hot Rod, Super Chevy, Chevy High Performance, Popular HotRodding.
From my living room to yours.  Or, they make good reading for the sit down/quiet time room, if you know what I mean!  biggrin
My Gen 1 small block stuff...
A couple of starters - use for cores or rebuild
A few alternators  - use for cores or rebuild
Stock HEI distributor
A bunch of brackets - alternator, A/C, P/S
A stack of pulleys
gone - 2 flexplates
gone - Holley 3310 (750cfm) vac sec. carb (needs rebuild/parts)
gone - Remains of a Holley "trick kit" - secondary springs, pump cams, etc.
gone - 10-bolt posi carrier (only)
10-bolt axle assy - open diff, drum to drum
Practically new radiator & dual fans for 95/96 Roadie or Impala
Used (rough) radiator & single fan for 95/96 Roadie or Impala
A/C condenser for 95/96 Roadie or Impala
Set of dual cooling fans (off late-model Audi)
Brand New - Ceramic coated headers - 88 to 95 Chev Pickup
Misc & assorted gauges
Not Bringing but available:
"mystery" 350 - rebuild core
TH-350 trans - used to be behind my 383
-- Edited by John D on Wednesday 26th of January 2011 111743 PM
