I can answer questions about parts and I can provide pictures upon request. Contact me for prices if interested by Text or phone 612-245-0023 Jim.
*Motor
327/300 (3782870) Motor comes with double hump heads, factory intake and exhaust manifolds. It comes with a Carter carburetor with glass filter and air cleaner assembly, PS Pump and brackets and Alt, and fan.
Motor ran well when pulled.
*Transmission
Muncie M20 with hurst linkage. It has a Mcleod Hydraulic throw out bearing mounted, but I do have the regular sleeve that is included. Transmission ran perfectly when pulled. Will need the shift handle.
*Radiator
Brass Harrison single core In good shape for 64-66. Driver side inlet.
Factory air box and factory style fan shroud.
New Cold Case CHE 542 radiator new in box 64-67.
*Tires
4 - 205/75/14 Coker BFG Silvertown redline tires mounted on steel rims, tires are in great shape lot of tread depth.
I have a 14 in full size spare also mounted on a steel rim.
All are 5-4 ¾ bolt pattern.
*MISC Parts
·2-CPP 500 steering boxes will need to be rebuilt
·Edelbrock 1406 carburetor used but in great shape.
·Holley 770 street avenger carburetor almost new.
·1 NEWAC Delco water pump ACD# 321-464 GM# 19152464 it is black in color.
Chevelle parts for sale
*Motor
*Transmission
*Radiator
*Tires
*MISC Parts
· 2-CPP 500 steering boxes will need to be rebuilt
· Edelbrock 1406 carburetor used but in great shape.
· Holley 770 street avenger carburetor almost new.
· 1 NEW AC Delco water pump ACD# 321-464 GM# 19152464 it is black in color.
· 2 Used rear upper control arms for 64-66
