-- Edited by 67ss on Sunday 20th of December 2020 07:40:33 PM
WOW, THAT IS a smoking deal !! New drive train for the Rambler ? Got a deal with the DNR for mosquito control next season to pay for the car ?
Yep it has a 3800 with a 5 speed manual. Need to swap some of the accessory drive from the rear drive engine to the supercharged engine to get the power steering and a/c on the correct sides. Figure I can also see if I can adapt the motor mounts into the rambler.
So what is with the Sea Foam treatment ??
I'm sure you will come up with a way to get the mounts in there. Jeeez, I'm starting to feel left out with all the new acquisitions in the club...
I think it has a stuck open or stuck on injector flooding a cylinder. Didn’t really check into it just backed it into the shed and shut it down.
Maybe, I had an injector stick open on a Nissan years ago and as soon as I turned the key on, it hydro locked the engine. Doesn't sound like you are using that engine anyway, so probably not an issue. Did you acquire a '68 Chevelle recently too...
I got a smoking good deal on it!
https://photos.app.goo.gl/ewBfdFRtie981upf9
