If it is rough, Karl may still have a very nice black hood you could paint cheaper than repairing a bad one and still paint.
The hood on the car had a like 5 pin holes through the surface. So I got a different hood that I am stripping to make sure there are no problems. Pass side just done so far good. Stripping the second part this afternoon. The body guy here in LC recommenced I get a different hood so that’s what I did.
So far, original primer, the yellow, another yellow, then a blue.
OK, and the replacement just happens to be blue too... I thought it was the one from the car...
Talk with Duane about the diff yet ? I finally got enough hours banked at Centerline for my son's Malibu repair and can start bringing money home...
Talked to Duane this morning. He pretty much said I would have a better idea then he would. I told him maybe I could trade it for some sheetmetal work like welding, He welds and has done multiple jobs for me; but is not comfortable with doing the butt welds in me trunk. He said he was fine with that or if I just sell it to someone. So Is that something your interested in or would you just like to buy it outright?
Not sure when/how I would be able to help you weld the trunk, but yes, I would be willing to do that either way. At this point, if you would shoot me a PM with a price, I can decide if I would rather pay you/him for the diff now and work out helping with the trunk when there is time.
So far good. Finished the lip and 3/4 of the top. No damage no pin holes or rust anywhere.j
Hood is in epoxy primer. My body guy suggested I bead blast hinges, hood lock, and bolts and pretty them up. Then he will bring up the hood and fit it. Then hood and car to the shop for an y metal work etc. Then paint.
What a clever idea to stretch the springs for paint.
Feb 6, 2020
Gotta love hot water heat!
I bet spouse loves the fragrance!
x2!
I have a 3/8" rod I slide inside to hold it spread after removing from the jack. I cut notches in the ends to keep it from slipping out. I "think" they are in my locker, somewhere...
Well there turned out to b a hole drilled hole in the upper left corner of the hood where they did a repair. I guess I should have had the whole top stripped before I bought it. So my paint guy has me stripping a second hood.. I think this one is good. Hopefully the hood will prove me correct.
-- Edited by jim larson on Friday 14th of February 2020 05:58:33 PM
-- Edited by jim larson on Friday 14th of February 2020 05:59:09 PM
-- Edited by jim larson on Saturday 15th of February 2020 08:49:59 AM
Starting to strip the hood. Hope there are no surprises.
So far top coat blue, then a yellow, under that another yellow. Tomorrow should yield even more. Going to take a couple of gallons.
-- Edited by jim larson on Thursday 23rd of January 2020 06:48:42 PM
You just couldn't leave it alone, could you...
x2!
