Like many of the projects we work on, not all of the hardware we need for the project is there. That is the case with the Beetle.
Does anyone know who stocks large quantities of metric nuts and bolts (like Fleet Farm has for their standard nuts and bolts)?
Fleet Farm in Circle Pines and Menards in Forest Lake have the drawers that give you a good selection, but you might only have a quantity of 3 or 4, if you are lucky. I called Fastenal in Forest Lake and I would have to order the metric hardware online with a 2 day delivery to their store or the house.
Right now, I am in need of 10mm and 12mm hardware, Grade 8 at a min. Ex: I currently need 10 - 12mm X 80mm X 1.5 thread pitch, grade 8 for the shocks and other suspension items.
Suggest that you try Ace Hardware
S&S industrial supply in East bethel. Anything and everything you will ever need. The have a $10.00 min amount typically.
http://www.ssindustrialsupply.com/
Hank, S&S is just down Hwy 65 from me if you need anything picked up then I can drop it off after work.
