He he does not have a part number listed . He also has a Holley and I don’t think the solenoid is the same for edelbrock?
Wow, I did a search and $165 for a "kit" !!
I ordered an SMP-ES9 solenoid from Rockauto for $55 and will fabricate a bracket. I may have some spare metal around here from some past project..
Should be about the same solenoid as what I found through Napa. I did buy the Holley bracket through Summit as I don't have your fab skills or the time to do it like you retired guys.
The Holley bracket is cheap and if it was even close to working with the Edelbrock, I might have bought it. The Edelbrock bracket must be made of a precious metal because it's about $60...
Help, I need a solenoid for the coupe and can't find Stan's reference to what he has been using...he has too many posts to go thru them all...
http://northstarchevelles.activeboard.com/t64718188/ac-carb-solenoid-project/
