I realized I really haven't had an alignment done on the Chevelle since I put the new wheels and tires on it, which has been 2 years now. Looking for what to do for specs. It's going to be done at Andover Wheel and Frame on my end of town. I had the alignment done many moons ago when I rebuilt the front suspension, but I know it probably isn't correct now.
I know someone has a good source for specs. I'm not doing autocross and don't have any plans to do it more than maybe a couple laps a year at the most.
Is anything modified, or suspension all stock?
Jul 5, 2018
This is for a 82!
Sent request to AllDATA for correct year.
I bet Chris P. can help also.
Here is a screen shot of an 82 Malibu. I bet they are pretty close. Remember lots of positive caster, (equal both sides) results in a quicker return after corner.
Better snap back.
-- Edited by more ambition than brains on Thursday 5th of July 2018 05:34:56 PM
-- Edited by more ambition than brains on Thursday 5th of July 2018 09:16:31 PM
Not at work to pull specs from the service manual.
Stock control arms, stock type ball joints, large Helwig front sway bar. Poly bushings, Viking coilovers, lowered some with those, . 245/45r17 front tires.
I also have the original specs, but I think factory specs might not be appropriate anymore? I can change caster, camber, toe, etc but where to stop so it’s not too much?
The only spec you may want more of than stock is the caster and that will be limited by the stock control arms and the fact that many GM's from that era have sagged inward at the front crossmember from age and use. All they can do for positive caster is remove all the shims and you get what is left. When I had Andrew's car aligned, they ran into this and barely got to positive with no shims. The alignment guy then added what was needed to get the sides equal. Ideally, the frame should be locked on a rack and spread back out a few degrees.
If the original toe still calls for a negative, that should be at zero or SLIGHTLY neg, not like with original bias ply tires.
More caster requires less toe.
I like to go as much + caster as possible, -0.5 camber, and 1/16" toe in.
Then drive it to see if it goes straight, or wanders at all. If it wanders, add a little toe.
When I went to radials a couple of years ago I was able to get +3 caster on both sides along with a -.05 camber, and 1/16 toe in. Car handles great. Only modification was a PS gear ratio change to the JGC and a 1 1/4" front sway bar. All other front end components are stock for 66.
This is for a 82!
Better snap back.
Actual 72 specs!
