Need a capacitor for the blower motor on a 60's gm push button radio
Trying to get the engine bay looking correct. I am missing the resistor for the fan blower that mounts on the firewall, original part number is 3886965, part # changed and style changed in the 70's. Used on Most GM cars with a push button radio. It contains the wiring to the blower and the other end has a connector that plugs into part of the enging harness. Also need the connector that is part of the engine harness. If you pulled the engine you would disconnect at the connection. If you parted out the can and saved the firewall then maybe you just saved the wiring. Top photo if of a 70's and later, bottom photo is of a 60's capacitor.
-- Edited by jim larson on Monday 18th of September 2017 01:52:23 PM
-- Edited by jim larson on Monday 18th of September 2017 01:55:35 PM
-- Edited by jim larson on Monday 18th of September 2017 01:57:11 PM
says out of stock and doesn't have the engine harness connector
Greg at S&M is where I would look.
Style was changed in early 70's, the again. They are available even from GM. But look very different than what was used in the 60's. Looking forsomething visually correct.
(763) 780 - 2861
S&M Electro-Tech, Inc
8836 Xylite St. NE
Blaine, MN 55449-5007
shop.docrebuild.com/1963-1967CorvetteBlowerMotorCapacitorGenuineGM3886965.aspx
