im about to begin clearing space in all my garage books/crannies. I will post stuff here and add to the list as I come across it.
If I don't get a hit on something, it goes away next Sunday night.
Most stuff has multi-year use, I'll post what it can off/out of.
More detail on stuff if interested, price is what you think is fair!
72 Chevelle console trim. Horseshoe shape and 2 side sticks.
72-75 NEW***Camaro back glass corner trim LH. p/# 9868731
76-81 Chevy car line parts book, complete
73-78 1/2-1ton GM truck parts book complete
1967 Motors auto repair manual
1970 Motors auto repair manual
1971 motors auto repair manual
Mitchell interchange book for mid -60s to mid -70s
67 Camarillo will trim plates, straight but need polishing
1968-1974 Motors auto repair manual
1946-72 1-1/2 to 2-1/2 ton truck series 40-50-60 parts manual
collision parts book 1980-1988 (good for part numbers)
1971-1978 collision parts book
72 only! pair of used LH/RH clear with amber side insert marker lenses
72 only! RH all amber marker lens. NEW NOS (1980s era). I have 2, but LH is different
2007-2008 hyper tech truck computer programmer-gas engine
2007 only hypertech power programmer diesel
Near new SBC water pump from my car before I switched to serpentine setup. Maybe 1000 miles.
Good Wrench transmission id guide for 200R4/700R4/4L60/4L80 and others
crash parts book for 80s era GM good for part numbers
New GM serpbbelt 12576747, 6 rib 2410mm
New v-belt 36015
new v-belt 44515
new front brake shield- 06-11 HHR/cobalt (I believe)
SBC non HEI coil bracket
72 rear console bracket that is welded to floor
72 prop valve mounting bracket
SBC distributor hold down fork
new in bag speedo gear 14077086 19 tooth
battery hold down thing that bolts to battery tray and holds lip of battery
door jamb striker but that's captured in the structure
throttle rod for carburetor (67 truck???)
72 floor carpet grommet for high beam button
bowtie shape lapel pins, gold or red (have 10 plus of each)
bowtie shape lapel pin blue/white says chevy trucks (have at least a dozen)
rectangle shape lapel pin gold outline, gold bow tie, black filler
heartbeat of America lapel pin
9x3 Chevy thunder sticker (have 2)
chrome-like Z71 box decal (have 10) custom design
Red "71 off road" box decal (7 pairs) custom design
silver Z71 box decal (only 1) custom design
Black Z71 box decal (have 2) custom design
gold Z71 box decal (have2) custom design
blue "71 off road" box decal custom design (1pair)
Plastic emblems-all NEW IN PACKAGE unless noted. Can research specifics For you.
"LS" #22674240 off 00 era Malibu Impala? Letters are separate
"V6" 22664169 off 00 Malibu imapala?
"Chevrolet" 10212757 off 90s truck?
"TrailBlazer" 15826226 off early 00 era. letters are separate
"Terraza" 15102875 letters are separate
"Grand" 89045569 (pkg of 2)
Chrome Caddy wreath 20890985
oval shaped "GL" 10419843
"CTS4" 25789084 all separate
"Z28" 10139552 90/-2000s era black
"350" connected, off Lexus Rx350 #75443-0E020
"Chevrolet" from 80s-early 90s car
"skyhawk" (with hawk) 22522314
"Snap-On 40 years 1965-2005" for toolbox
"Chevrolet" high tech print with red bow tie, off 90s. very thin
"Fleetwood" gold, 20747494
"Chevrolet silverado" 15" long
Black/chrome Caddy wreath 3542782
"jimmy" black with gold face 15963239
"1500" with bow tie on left. 90s era
"monte Carlo" 10178412 separate letters from era of Monte with block letters not script
"prizm" 94849070
"sts" 3525747 black with chrome edging
"GMC" 15195869 red with chrome edge, all connected
round Buick tri-shield 25630930
"impala" 10302441 dark grey? 90s or later era
rectangular olds rocket 22521879
"VUE xe" 96848695 the VUE are separate
"32 V Northstar" 3538464
"Hybrid 2mode" 15933399, H is green and heavily styled,
"LSi" 30009182 from Chev Tracker? Silver
Oval toyota logo grey/smoke # 00577-aan40
Rectangle saturn logo 2.5" tall
small Nissan logo 2" tall
"X'tre'me" aftermarket emblem
Round truck wheel centercap decal black with gold bow tie 16593434
round wheel center cap decal Buick tri-shield 10273068
round Buick trishield chrome 15259668. Outline only, shields are open. This is like a bezel
Gate decal "Chevrolet" outline 15785771
"ranger"
Ford oval (good used)
"SL" on truck cab by door, rounded corner rectangle
"duramax diesel" from door, good used
impala donkey shape from 00-09 era Impala on sail panel, faces right, good used.
1972 drum brake shoes, cylinders, hardware-all in real good shape
master cylinder (x2)
brake booster (x2)
steel timing cover
ac compressor-serpentine setup
87-up 350 crank
87-up flexplate
87-up balancer
NEW in box LS cylinder head 12629049 (399 casting)
NEW LS era clutch pkg, 24255748
new Delco round air filter 3-3/8 tall with metal mesh 6484235 (have 4)
R-12 cans, 12oz each (have 10)
stock steel centerbolt valve covers (pair)
front Chevelle speakers
chrome "street machine" emblems (dozen plus)
rear end center section from an s-10, no guts
rear end center section from later model GM truck, no guts
stainless look braided hose cover kits for whole engine (have 2)
-- Edited by bowtie on Sunday 4th of June 2017 09:53:45 AM
-- Edited by bowtie on Sunday 4th of June 2017 10:00:56 AM
-- Edited by bowtie on Sunday 4th of June 2017 10:06:01 AM
-- Edited by bowtie on Sunday 4th of June 2017 10:23:08 AM
-- Edited by bowtie on Sunday 4th of June 2017 10:43:25 AM
-- Edited by bowtie on Sunday 4th of June 2017 10:59:02 AM
-- Edited by bowtie on Sunday 4th of June 2017 11:32:55 AM
-- Edited by bowtie on Sunday 4th of June 2017 11:44:37 AM
-- Edited by bowtie on Sunday 4th of June 2017 01:35:56 PM
-- Edited by bowtie on Sunday 4th of June 2017 01:41:10 PM
-- Edited by bowtie on Sunday 4th of June 2017 03:50:10 PM
New v-belt 36015
new v-belt 44515
"prizm" 94849070
"ranger"
brake booster (x2)
steel timing cover
87-up 350 crank
87-up flexplate
87-up balancer
