Looking for a recommendation on upgrading from front drums to discs. Looking at this Wilwood kit: Wilwood Brake Link
I don't want to go any bigger than 12" rotor's to stay within a 17" wheel.
Thanks.
Mar 29, 2017
First off, I'm no expert, but I have done a lot of reading and researching brakes for our race car. You can fit a 13" rotor inside a 17" wheel. It all depends on what your plans are. If it's just a cruiser then that kit you linked to will work perfect. Pretty good price too since everything is included. Those 4 piston calipers are very nice also. Might even be a little over kill for a street car. (as of now, our race car only has 2 piston) If you plan on any track time, then you'll definitely want to go with at least a 12" or better yet 13" rotors and 4 piston calipers.
Mar 29, 2017
Another thing I just thought of is, you want to make sure your master cyl is compatible with the calipers you're using. Since that kit is designed for a Chevelle, I'm sure the stock MC will work. Once you start getting into multiple piston calipers, large piston calipers and rear discs, and all that good stuff, you have to increase the MC piston size to push more fluid and balance out the system.
This is who provided the Front & Rear disc conversions for "Blackie".
For a cruiser, I'd stick with OEM type brakes so you can get parts if you're on the road somewhere. This is a big reason why I went with C5 brakes, so I could get parts at NAPA or Autozone if needed.
I bought aftermarket 2" lowering spindles which use mid-80s Camaro brakes.
A stock Chevelle master will work, but he needs to get one for disc/drum...
Thanks everyone for the ideas. I was interested in that Wilwood system, but you guys are probably right that I don't want to break down in Podunk, Missouri and not be able to find parts.
John D.-MP has some nice systems and probably worth the $$, but trying to keep it in the $500-700 range. Found this one from Right Stuff that includes completely new spindles: Right Stuff brake link
That looks like a good kit. Calipers are probably copies of original, but don't state if they are D50 or metric. either way, you should be able to find replacement parts locally.
Thanks.
Check these guys... MP Brakes
