Since I am rebuilding my carb in hopes of stopping leaks and cleaning the intake, etc so that I can touch up some paint issues, I though maybe I should check the torque on the intakes and heads? There is a little carbon/oil intake leak hear and there, mostly at the front corners of the intake and heads. Or is this a waste of time. Not much work, just a new set of valve cover gaskets. They I could look things over and check the lash settings of the valves/push rods. Thanks.
