Let me know. I need to move it, so will not hold until the next meeting sorry.
17" Flex-a-lite Fan to cool your big or small block - Reversible for push or pull
Chevelle stock cross member supporting a TH350 trans or Muncie No cracks or bends - ready to fit
Pulled from my 72 Chevelle as I switched to a 700R4. Replace your rusted one. Can use if your converting to another trans too. Don't buy aftermarket! Go with a geniune OEM real steel USA part! There is a reason these last so many years.
(3) Wheels and Tires to fit GM Chevelle A-Body Camaro etc. Use for burnouts!
I had given my buddy one of the fronts for a spare a while ago :0( So you can use it as a spare also and then use the rears to replace yours Or use it for the track! Tires are virtually new!
Rear Adjustable-Control Arm-Kit A-Body Chevelle GTO Monte Carlo Cutlass
I only used to fit to my 72 chevelle. I ended up going a different way.
Southside Machine Sport Suspension kit includes a set of tubular rear lower control arms and a set of adjustable rear upper control arms. This control arm kit is a direct bolt-on replacement designed to minimize wheel hop, improve corning and help track consistency on your GM “A” Body vehicle. Stock control arms are on the borderline of junk, bushing deflection and rusting weak stamped material add for traction loss and poor handling ability. Whether your car is a weekend cruiser or weekend track addict this kit works on all applications. Lower control arms feature greaseable bushings, fully boxed and welded construction for the most in strength and correct provisions for adding a stock or aftermarket sway bar. The included adjustable upper control arms allow you to adjust your vehicles pinion angle and recenter the rearend for optimum performance, precise handling and improved traction. Adjustable upper control arms are constructed of CNC machined 0.250" steel mounting plates, heavy wall DOM tubing and heavy duty poly bushings to handle the most severe abouse you can throw at them.
GM A-Body Chevelle Camamro Nova rear sway bar for non-boxed rear control lower arms!
I pulled from my 72 Chevelle to switch to a differnet one is all. This is a really cool kit that allows you to put a large sway bar on your stock lower rear control arms. You just need to drill 4 holes. Super easy. Includes hardware.
New Power Steering reservoir from Tom Lee's Power Steering custom done for hydroboost
Will fit his power steering pumps or any GM one. Includes gaskets. I went with a different one on my kit is all. This includes the extra spout you need for your return line so you don't have to use the tee fitting which has been know to cause issues.
-- Edited by gearlube on Friday 29th of August 2014 12:39:10 PM
Dang,
Can you hold till Sunday? I would love the disc brake kit and front and rear shock setup and adjustable rear links.
John I sold the disc brake kit. The other pieces I have. Since your a fellow club member, for you I can hold and pull off. Let me know and PM me.
The disc brakes were what I was really after, the other stuff was more since I am there, as I would have been used them temporally until I figured out what I direction I want to go and then passed on to the next person. So no need to hold for me.
Great prices by the way.
Okay thanks. Ya priced to move and maybe help someone else with their projects. Sorry John. You know this stuff can go fast!
I'll get the front shocks.
No pics of the tires or brand info ??
I am interested in them but need to see the tread design.
Tom, I'll buy the rear stock control arms and rear sway bar from you.
I need the braces for the vert, and will store the others for the next project.
Thanks!
-- Edited by SShink on Friday 29th of August 2014 04:28:56 PM
Mitch I will post some pics as soon as I am done working with the brand
Never heard of the brand but the tread looks good. I'll get them too.
We will be at Gerten's in Inver Grove heights tomorrow and could run down from there. Are you going to be around tomorrow ?
Yes will be home tomorrow working on the Chevelle. Just text or call me. Do you have my number? I will PM it to you.
Send it via PM, please.
Probably be down later morning.
PZO said
Sep 1, 2014
I'd like to talk to you about the rear Southside Machine setup you have for sale. I'm new to Northstar so just getting use to the site. I'd like to change the rear setup on my 72 chevelle drag car. please call me at 612-418-5604 MARK
Front P195 / 65R15
Rears are P255 / 60R15
72 CHevelle or GM A-Body rear drum kit in working condition
Replace your old rusty or worn out drums. Pulled to switch to disc and were in perfect working order.
GM A-Body Chevelle Camamro Monte Carlo Nova Rear stock springs and new KYB shocks
I pulled from my 72 Chevelle to switch to coilvoers is all. No sag, never cut. Shocks are new!
GM A-Body Chevelle Camamro Nova Front stock springs and new KYB shocks
GM A-Body Chevelle Camamro Monte Carlo Nova Rear stock Front Sway Bar and all hardware
I pulled from my 72 Chevelle to switch to a larger one for racing is all. No sag, never cut.
70-72 Chevy Camaro rear bumper in chrome. Its stock! and in good shape
No rust through. Lots of shine left.
GM A-Body Chevelle Camamro Nova complete rear lower upper control arms and F41 braces
I pulled from my 72 Chevelle to switch to adjustible is all. All hardware too!
Ebay:
Thanks!
Cool, thanks.
Are they directional tread ?
Mitch here are the pics.
