Dynomax 17221 muffler ( 3in in and out) plus turn downs $60
Grant Formula GT 773 steering wheel $20
70 El Camino stock sway bar...Free
-- Edited by Enganeer on Friday 15th of August 2014 10:41:49 PM
John, do the front brake spindles have the hubs on them? If so I would be interested in the brake stuff.
Spindles come with it.
I can bring to the meeting.
Yea that would be great, thanks.
feel free to make offers
John, if that's an underdash mount, I'll take the radio/mounting case.
I mostly want the mounting case, as it might be time to get the radio/dvd/mp3 player out of the glove box... So, I'll get rid of the radio for you too.
Thanks.
Added a couple more things
FREE 5.7l , 350 block, crank, plus parts.
Block casting 14093638, 1 pc rear, stock bore, 2 bolt, flat tappet cam with mechanical fuel pump casting still there. Crank looks good and spins freely. Greased crank and bores for long term storage, should cleanup easily.
includes:
box of std pistons and rods from 2 engines.
oil pan and front timing cover
bag of rockers from heads, gm stock self aligning
$10 Pair of stock black center bolt style valve covers plus hardware, gaskets and grommets and oil cap (extended tube versions and regular cap)
Added compressor.
Speedaire Model 52185. Needs a seal replaced on crank side (leaks) and has an epoxy repair on the casting (been that way for years). Ran very quiet but I don't have 220 yet in my detached garage and no real place in my main garage. Also have a dryer that be hooked up. $200 for it all.
I'll take the compressor.
How soon do you need it gone?
DAMN, just saw this and was going to take it.
You beat me to it again...
I need to extract it from a corner. I would like to get the space sooner than later. I need to make room for some tools.
Are you going to the meet next week? If so, I might be able to bring it or you could swing down afterwards and pickup.
Apr 11, 2014
Me too... Missed it by about 15 minutes this morning.
includes:
I'll take these including valve covers. Going to Chris P's for the meeting? If you get to my place with the stuff, I'll drive us up there.
I am coming up to the meeting in 2 weeks.
Let me know if you need it gone sooner than that.
Well I was off a week I guess.
I think I can be able to move it to the main garage this week short term.
More FREE STUFF
I had listed a trailer awhile back but now takers, so now that is cut up but the front A-section is decent, fenders with lights and rear axle are still available for now. Tires are getting transferred to new wheels for my other trailer, so if you want the axle, I have the rims to go with it.
Craftsman weed whipper 2 stroke gas - the fuel hose sent bad, I was going to fix it awhile back but used my electric instead. Some assembly required. Good for fun project with the kids. I sure you can download a manual from sears.
john, are you able to haul the block and stuff to my place on club meeting day? I can dig out my little trailer if need be.
No problem hauling the stuff...I gots me a truck now.
Cool, thanks!
John you still have the Performer intake?
yup.
John I forgot to ask you about the brake stuff when you were over this weekend. Is it still available?
Yes it is. lol, I brought the stuff to the meet but I forgot who asked when I was at the meet. The lower control arms are still attached and need to be removed.
When would you want this stuff? Sooner is better for me. I work in Mounds View by 65 and can meet somewhere and can give you the stuff, just give me the control arms and steering arms back when you can.
-- Edited by Enganeer on Tuesday 29th of April 2014 11:57:54 AM
I think you are close to Bryans work? If you can drop them off with him I can stop and grab them and then drop back all the stuff you need back to him again?
I'm cool with that, I'm a good middleman
No problem then. I will drop them off sometime this week.
John, parts you wanted back are with Bryan again when ever you can stop and grab them.
Thanks.
Can bring stuff down to meet if anyone is interested.
cleaning out some stuff of the garage
Radiator 2 core with trans cooler...19 x 34?...Free
Edelbrock 2101 performer intake $30 Has one helicoil on one of the carb mounting holes.
Gm cast 4 bbl intake 3919803 manifold date coded 1 28 67 $20
Thanks.
includes:
Added compressor.
More FREE STUFF
Cool, thanks!
Thanks.
