Just seeing if there is any interest here. Since I have traded my trailblazer in, I have a posi rear end I pulled from the salvage yard that I never got around to swapping out.
Fairly complete minus the emergency brake cables and brake calipers (has caliper brackets though). I replaced the rear backing plates with brand new one. Gear ration is GT4 (3.73) gear, differential is G80 locker. This one is from 02, so it has the bottom drain bolt, unlike later years.
Just want this stuff out of here...take it soon or I will recycle it.
-- Edited by Enganeer on Sunday 23rd of March 2014 06:26:06 PM
-- Edited by Enganeer on Saturday 5th of April 2014 11:19:13 AM
I'll throw a bunch of other parts to sweeten the deal
All were pulled at 130K as part of routine maintenance.
Alternator
Clutch fan
sway bar links
ignition switch
tensioner
CV axle (cardone replacement) (about 30K on it) ( I had bought two with the intention of replacing both at sometime. When I replace the grease seal on the driver side diff, I stuck the other new one in, never got around to the passenger side)
Whodatothere said
Mar 26, 2014
I want it. How do I get in touch?
Whodatothere said
Mar 27, 2014
I don't need all them extras. Just the gt4 g80. If I have to take it all, then bring it on. I hope you will ship to Houston. Call me at 9795591688 if you need address. Thanks, brian
Sorry,
Just doing local pickup only.
Whodatothere said
Mar 27, 2014
Could I send the money for shipping plus a little extra for your time and trouble? Brian
Sorry,
I have local interest here. Way too much work to try and drag around to a shipping company and find a large enough pallet. It would cost way more to ship it than it would to get it used from a salvage yard.
Whodatothere said
Mar 27, 2014
I know it would be a pain. Having no luck so far finding in salvage but steady at it. Thanks anyway
4 salvage yards in Houston all show one for sale: Big Leroy's Beltway, Bronco, Airline, plus at least 2 dozen other yards in Texas.
Use this site,
put in
2002
Chevy Trailblazer Rear axle assy
State: Texas
Put in your zip code
select Gt4 on next screen
And Bam!
You got all tons of options plus I can guarantee that rear axles assy will be in much better shape on the outside than one from up here.
If you want to get the HD version of the axle, select the Trailblazer Ext model.
Alternator
Clutch fan
sway bar links
ignition switch
tensioner
Use this site,
put in
2002
Chevy Trailblazer
Rear axle assy
State: Texas
And Bam!
http://car-part.com/
