I have three 3855961 blocks for sale, two pairs of 3856206 heads, one pair of 387207 heads, two timing chain covers, two 6223 forged steel cranks, a set of 7/16th rods, two 66 holley intakes, a 66 bbd distributor, a chevy v8 distributor, a BBC fan clutch (hayden), an original bbc thermostat housing, a couple of 66 holley carb and some parts, two 66 chevelle radiators, some fan spacers, and a couple of electric radiator fans.
I also have some other 66 parts, like an original KK tack for the 325 HP application. And some 14" or 15" steel wheels.
If interested in anything email me ( members section), PM me, or see me at the bow-tie lunch. Thanks
How tight is the Hayden fan clutch. I would be interested in discussing that and a fan spacer at the brunch in a few weekends.
Hey Chris I only used the fan cult for a couple of months while my original Eaton fan clutch was being rebuilt by a guy in FL. The 66 BBC fan clutch had a mounting distance of 1.5" ( of course this is with an original radiator and fan shroud and fan so that the blades will sit the correct distance into the shroud. This Hayden has a mounting distance of 1.4" If you look in the Hayden catalog, I think they had the wrong clutch recommended , I believe the mounting distance they say to use is 1.75" (Original SBC mounting distance was 1.75" in a chevelle) which is the small block fan clutch. The model # is 2711. The model Hayden lists is 2710
Any specific distance or part # that you are looking for a fan spacer? I think I have two or 3 different distances. As far as I know you do not use a spacer with a fan clutch.
I still have the original BBC Harrison radiator and the original fan shroud. Been wanting to get a stock setup for now and get rid of the flex fan thats been there for years.
