Useful list, but it needs to be updated... nothing newer than 2004 on it.
Thanks for posting it though! :)
Oct 2, 2013
It is interesting, I never knew they made a steel casting, looks like they were on 99-00 LQ4 motors. The easiest way to ID the LS heads is the 3 digit casting number on the spark plug side of the head. Bryan's list has part numbers, and several part numbers were made from the same casting. The 243 or 799 casting are the most popular Gen 3 head.
Here's more reading than you ever cared to do on LS heads:
933 97 aluminum perimeter bolt 5.7 806 97-98 aluminum perimeter bolt 5.7 853 99-00 aluminum center bolt 5.7 241 01-03 aluminum center bolt 5.7 (some late MY00 cars got 241 castings) 243 04 up LS6 aluminum center bolt 5.7 ***These castings were also used around 05 in truck applications*** 862 99 and up 4.8-5.3 Truck heads 706 99 and up 4.8-5.3 Truck heads 799 05 and up 4.8-5.3Truck heads ***reportedly came on a few corvette's too*** These are basically 243 Heads 873 99-00 LQ4 6.0 Iron center bolt heads 317 01 and up LQ4 and LQ9 6.0 aluminum center bolt heads 035 01 - 04 LQ9 6.0 aluminum center bolt heads
What you need to know: The standard issue LS1 heads is best all-around head for the street / strip engines . A thorough porting and millimg job plus a valve upgrade on these will really wake up your engine.The heads have undergone only minor revisions since their introduction in 1997 , most notably a switch from perimeter to center valvcover bolt configuration for the 1999 model year. Each style has its own dedicated valvecovers and coilpacks mounting apparatus.
Casting Number 243 Head: 2001 LS6 5.7 Liter Passenger Car Material: Aluminimum Part Number: 12564243 Combustion Chamber Volume: 64.45cc Compression Ratio: 10.5:1 Intake Port Volume: 210cc Exhaust Port Volume: 75cc Intake Valve Diameter: 2.00 inches Exhaust Valve Diameter: 1.55 inches
What you need to know: The LS6 cylinder heads is essentially a tuned-up version of the LS1 head. At 65cc, the combustion chamber is slightly smaller and more efficient than the LS1. The more efficient design shortens burn times and ultimately means less ignition timing advance is required to produce the same power. And because less timing allows more efficient combustion, the Ls6 heads allow the engine to produce more torque. The exhaust port is a unique D-shape that improves flow. LS6 heads are the best choice only when all-out power is needed. Be prepared for a big price tag at the dealer or steep core charge from your head porter.
Casting Number 706 and 862 Head: 1999+ 4.8L / 5.3 Liter Truck Material: Aluminimum Part Number: 12559862 12561706 Combustion Chamber Volume: 61.15cc Compression Ratio: 9.5:1 Intake Port Volume: 200cc Exhaust Port Volume: 70cc Intake Valve Diameter: 1.89 inches Exhaust Valve Diameter: 1.55 inches
What you need to know: These small combustion chamber truck heads offer no advantage over an LS1 head except the smaller combustion chamber. This along with milling of the deck surface will allow a slightly higher compression ratio to be achieved. Because of the smaller intake valve installed in these heads a valve upgrade is practically mandatory.
Casting Number 873 Head: 1999-2000 LQ4 6.0 Liter Truck Material: ***Cast Iron*** Part Number: 12561873 Combustion Chamber Volume: 71.06cc Compression Ratio: 9.5:1 Intake Port Volume: 210cc Exhaust Port Volume: 75cc Intake Valve Diameter: 2.00 inches Exhaust Valve Diameter: 1.55 inches
Casting Number 317, 035 Head: 2001+ LQ4 and LQ9 6.0 Liter Truck Material: Aluminimum Part Number: 12562317 -LQ4 12572317 -LQ9 12572035 -LQ9 Combustion Chamber Volume: 71.06cc Compression Ratio: 10:1 LQ9 Flat top pistons Compression Ratio: 9.6:1 LQ4 Dish piston Intake Port Volume: 210cc Exhaust Port Volume: 75cc Intake Valve Diameter: 2.00 inches Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers Chamber 71.06cc----0.100---0.200--0.300--0.400--0.500--0.550--0.600 Intake 210cc-----------66-----142-----196---228----236---238-----240 Exhaust 75cc----------59-----104-----137---155----167---173-----177
What you need to know: The LQ4 head received aluminum heads starting in models year 2001. All other features are the same as previous years iron heads. This is the workhorse head for street / strip turbo and blower cars. They offer a large combustion chamber that lowers compression ratio making them perfect for a forced induction application. Swapping on the LQ4 head drops the compression ratio of a typical LS1 engine to 9:5.1 The Cast-iron casting are heavy!
So you want to figure out how much to mill:
It takes about .005" milling of the block deck to remove 1cc of volume. It takes .007" milling to remove 1cc from an LS1 head
Simple Milling Math:
You have a stock 66cc chamber and you want to get down to 63cc
66-63 = 3. You have to remove 3cc's
.007 x 3 = .021. So to get your 66cc chambers down to 63cc you'd have to mill ~.021.
You can also do the reverse, say you want to mill a head .030 to figure out how many CC's that removes you take .030 / .007 = ~ 4.28. Milling a stock 5.7 head .030 puts your chamber at ~ 62.
241 cast heads were Die Cast which is a process that smooths up the ports a bit compared to the Sand Cast procedure that was done on the 806 and 853 heads. Once ported any "advantage" the 241 cast had is moot.
Same Info applies to the: 4.8L/5.3L Truck 862 and 706 Head castings While the 706 Heads are a SPM = Semi Permanent-mold And considerd to be a more consistant head casting then the 862 wich are Sand cast, Once ported There Is no difference.
This appears to be one of the common misconceptions about heads having the 243 casting no. -- they are not necessarily LS6 head assemblies. The LS2 heads (243 or 799 casting) have the "heavy" standard LS1 valves. However, they do have the LS6 springs.
Only the true LS6 engine heads have stainless steel (not titanium) hollow stem valves (the exhaust stems are sodium filled). These valves are slightly longer than LS1 valves too.
The LS7 heads do have titanium valves.
New LS2 heads are about half the price of new LS6 heads (check sdparts.com). GM is "really proud" of those hollow stem valves!
Oh, if you have the 799 castings -- the only thing "Corvette" about them is the valve springs/retainers! Still a desirable set of LS1 heads though!
Supposedly, the 243 mold was done at GM Research, the 799 mold furnished to other vendors. The same vendor may have the 243 and 799 mold.
Both heads have identical sized intake and exhaust valves
Yeah, I just nabbed it off another website, who got it off another, etc. If I come across a more encompassing one, I'll post it.
Added this to our "Tips & Tricks" page on the website - Thanks guys!!
I came across this today, thought I would pass it on to everyone, especially those who are interested in the LS engines
Small Block Chevy LS Cylinder Heads by Casting Number
10215339 – LS Small Block V8 1997 346, LS1, aluminum, 68cc chambers
12480005 – LS Small Block V8 2000 LS1, GTZ, aluminum, 38cc chambers, 2.125/1.625 valves, angle plugs
12556743 – LS Small Block V8 1999 325, 5.3L, aluminum, truck, van
12558806 – LS Small Block V8 1997-1998 346, LS1, aluminum, 68cc chambers
12559853 – LS Small Block V8 1999 346, LS1, aluminum, 68cc chambers
12559862 – LS Small Block V8 1999-2000 aluminum, LS, 4.8 or 5.3L
12559895 – LS Small Block V8 2000 325 (5.3L) aluminum
12561706 – LS Small Block V8 2001-2004 325 (5.3L) aluminum
12561873 – LS Small Block V8 1999-2001 364, 6.0L, LS, 71cc chambers, cast iron
12562317 – LS Small Block V8 2001-2004 364, 6.0L, LS, 71cc chambers, aluminum
12564241 – LS Small Block V8 2000 346, LS1, aluminum, 68cc chambers
12564243 – LS Small Block V8 2001 346 (5.7L LS6) or 364 (6.0L LS2), aluminum
12572035 – LS Small Block V8 2001-2004 364, 6.0L, LS, aluminum, 71cc chambers
12550592 – LS Small Block V8 1997-up 346, LS1
12559846 – LS Small Block V8 1998-up 346, LS1
12560621 – LS Small Block V8 1998-up 346, LS1
12562174 – LS Small Block V8 1998-up 346, LS1
10106178 – LT Small Block V8 1990 350, LT5, Corvette ZR1, DOHC 32-valve, aluminum, passenger side head
10106179 – LT Small Block V8 1990 350, LT5, Corvette ZR1, DOHC 32-valve, aluminum, drivers side head
10125320 – LT Small Block V8 1994-1996 350, LT1, cast iron, Caprice 9C1 Police, Impala SS, Cadillac Fleetwood, Buick Roadmaster, reverse flow cooling
10128374 – LT Small Block V8 1992 350, LT1, 53cc chambers, angle plugs, aluminum, reverse flow cooling, 175cc intake ports, 68cc exhaust ports
10174389 – LT Small Block V8 1991-1995 350, LT5, Corvette ZR1, DOHC 32-valve, driver side, aluminum
10174390 – LT Small Block V8 1991-1995 350, LT5, Corvette ZR1, DOHC 32-valve, passenger side, aluminum
10205245 – LT Small Block V8 1993 350, LT1, aluminum, reverse flow cooling, 175cc intake ports, 68cc exhaust ports
10207643 – LT Small Block V8 1994-1996 350, LT1, aluminum, reverse flow cooling, 175cc intake ports, 68cc exhaust ports
10208890 – LT Small Block V8 1994-1996 265, Baby LT1, L99, cast iron, reverse flow cooling
10225121 – LT Small Block V8 1994-1995 350, LT5, Corvette ZR1, DOHC 32-valve, drivers side, aluminum
10225122 – LT Small Block V8 1995 350, LT5, Corvette ZR1, DOHC 32-valve, passenger side, aluminum
10239902 – LT Small Block V8 1996 350, LT4, aluminum, reverse flow cooling, 195cc intake ports, 54cc chamber, angle plugs
12529742 – LT Small Block V8 1995-1996 265, Baby LT1, L99, cast iron
12551561 – LT Small Block V8 1996 350, LT1, aluminum, reverse flow cooling
12554290 – LT Small Block V8 1994-1996 350, LT1, Caprice 9C1 Police, Impala SS, Cadillac Fleetwood, Buick Roadmaster, reverse flow cooling
12554291 – LT Small Block V8 1995-1996 265, Baby LT1, L99, cast iron
12555690 – LT Small Block V8 1996 350, LT4, aluminum, reverse flow cooling
14088526 – LT Small Block V8 350, LT1, aluminum
Even more detailed info:
Casting Numbers 241, 806, 853
Head: 1997+ LS1 5.7 Liter Passenger Car
Part Number:
12559806 (1997-98) Chambers = 69cc
12559853 (1999-00)
12564241 (2000-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Chamber 66.67 cc------0.100--0.200---0.300---0.400---0.500---0.550--0.600
Intake 200 cc------------67----122-----178-----215-----219-----223---227
Exhaust 70 cc------------52-----97-----133-----156-----170-----76----180
Casting Number 243
Part Number:
12564243
Chamber 64.45 cc-------0.100---0.200--0.300--0.400---0.500---0.550---0.600
Intake 210 cc------------62------126----184----224-----251----256----257
Exhaust 75 cc------------57------108----143----163-----176----180----183
Part Number:
12559862
12561706
Chamber 61.15 cc----0.100--0.200--0.300-- 0.400--0.500---0.550---0.600
Intake 200 cc----------63 ---128----179-----210----218----221-----226
Exhaust 70 cc----------54 -- 93 ----121----145-----163----168----174
Casting Number 873
Part Number:
12561873
Part Number:
12562317 -LQ4
12572317 -LQ9
12572035 -LQ9
799 Vs. 243 Info Copied From pillboxesghost Post's in ths threadhttp://www.ls1tech.com/forums/conver...l#post10241473
