Just when parts were starting to get happy with each other after the reassembly thrash on the vert, I was at a show and found a deal on wheels and tires that I couldn't pass up. Needless to say, the rims were a very good deal, and I found a set, yes a set of tires for less than the cost of one tire in the swap meet!
The wheels are 17X7 and 17X8 Showheels brand (from Australia) that are made for 50's, 60's, and 70's vintage muscle cars, so the backspacing is good. The Goodyear tires were taken off a Dodge Magnum with about 20K miles on them, and other than one with slight cupping, they are in great shape. I like the 'old skool' 5 spoke ET type mag look with the modern size.
A couple of teaser pics from my cell phone, as I will add better ones later:
Of course there had to be a problem installing them... when a lug nut cross threaded when removing the old rear rims. With the stud spinning, the only option I had was to take the air grinder to it and cut it off. That was after trying other methods, but I did get it off without damaging the old rim, which was a relief. Speaking of which, I'm keeping the old rims/tires so I can swap back to the 'stock' look in 30 min. or less.
What do ya think?
I like them but save the stockers.
I like them also, blends in with the rest of the car nicely. You guys are making we want to go spend lots of money to get some for the camaro.
Very nice! The tires look pretty tall... how far off is the speedo now?
The tires are 215's, and about 1.5-1.75" taller than what I took off (I think 27" tall?). The speedo reads 10 mph high, but that's better than what it was. The rpm dropped about 250 at 70 mph, so now I'm running about 2750 instead of 3K+, which is better.
The speedo gear in the trans is the red one, which is supposed to be right for 3.08 gears which I have, but it's still reading high. Using the GPS as my speedo now...
Aug 30, 2013
I like it, similar look to my new ones .
I agree with Dashboard, keep the old ones that way the new owner can pick which set he likes best.
Use this link Stan if you want to try and correct your speedometer. I would bet John and Master might have gears to get you set up for an old Th350 trans.
Aug 31, 2013
I love the new wheels!
Looks even better in person!!
Had a nice mostly overcast morning today, so I ran out to the Dakota Co. Fairgrounds and snapped a few pics to get a better look at the new shoes:
Looks great!! Still has your old Skool look
Once you get a color/number for drive/driven gear, post it here. I might still be able to get you one, or at least the part number.
Back in Black said
Sep 3, 2013
I think they look great!
~~~~~PERFECT~~~~
The next set of rear tires could stand to be wider but the wheels are killer....
NOW, as Chris said, where do we get these great looking bargains ?????
66 RAT wrote:
Like the others, I like the new wheel/tire combination. I also like the pictures taken at the fairgrounds. The Dakota Village buildings make very nice backgrounds for the shots. Can anyone drive in there at any time and take advantage of their "photo studio"?
Thanks Ron and everyone for the positive comments. I really like them other than wanting a little wider rubber in the back but I can do that after the tread gets worn down from slippage....
I think the fair grounds are open all the time as far as that side where the buildings are.
-- Edited by SShink on Sunday 8th of September 2013 04:24:16 PM
66 RAT said
Sep 8, 2013
What do ya think?
http://www.tciauto.com/tc/speedometer-gear-calculator/
~~~~~PERFECT~~~~
