Anybody have a good set of used 3.08 gears they want to sell?
I might have a set but need to check and see if I still have it.
Cool that would be great!
Chris,
I have the gear and open differential. There was some rust on the ring gear, not much, but you can have them as I don't think I will be using them.
Awesome John, I will try and connect up with you or if you are coming to the show this weekend maybe you can bring them with?
if you can get it to me at Friendly sometime, I can pass it off to Chris.
I can't make the meet this weekend but I could drop them off with Bryan tomorrow.
Bryan,
Will you be around tomorrow?
YUP, I'm working from 7-3:30.
Thank you very much John.
Dropped a box off with Bryan.
On the open differential, I recall the cross pin bolt broke on inside...It's been awhile since I worked on it but I think I was able to drill it out and remove the broken portion but check it out.
Bryan,
