Factory and aftermarkt parts. See Pics at the bottom.
Chevelle Sumped Fuel Tank
Fits 70’-72’ Chevelle and possibly other GM A Bodies. Aftermarket sump with multiple outlets (-10). -10 Return fitting. $75
Mallory Fuel Pump for Fuel Injection
Bought new last year. 500 miles on pump. Works perfect. PN MAA-11106M $220 on Summit:
http://www.summitracing.com/parts/maa-11106m
$120
Aftermarket Fuel Filters - SOLD
14 x 4 K&N Filter
14 x 4 K&N Filter. About 800 miles on it. Comes with top and bottom filter covers. $30
Trick Flow Fuel Pump
About 1,000 miles on this. $140 from Summit: http://www.summitracing.com/parts/tfs-25003/overview/
$60
New Chevelle Throttle Cable - SOLD
Carb Fuel Pressure Regulator Setup - SOLD
4150 Feed Line and BG Regulator - SOLD
Holley 4150 Carb
See list number. This was a 4160 carb and had the 4150 rear metering block kit added. Carb ran fine last summer. $60
LS Electric Fan Switch
Painless part number 30113. $40 off of Summit.
http://www.summitracing.com/parts/prf-30113
$20
1 inch poly square bore (Holley) carb spacer - SOLD
-- Edited by seagrams72 on Monday 25th of March 2013 07:24:43 PM
seagrams72 wrote:Factory and aftermarkt parts. See Pics at the bottom.New Chevelle Throttle CablePN 336969R from SS396.com. Never installed.http://www.ss396.com/mm5/merchant.mvc?Screen=PROD&Store_Code=chevellecamino&Product_Code=336969R$104150 Feed Line and BG Regulator4150 feed line (Black) $20Barry Grant Return Style Regulator $20Both items together $30Holley 4150 CarbSee list number. This was a 4160 carb and had the 4150 rear metering block kit added. Carb ran fine last summer. $60
$10
Im interested in these items. Forgot to ask, any idea on the CFM of the carb?
More Pics:
Last of the Pics:
Ill take them both. Did you sell the other stuff on Craigslist or something?
If Chris changes his mind on that carb I am also interested.
$120
14 x 4 K&N Filter
$60
Holley 4150 Carb
$20
-- Edited by seagrams72 on Thursday 4th of April 2013 02:54:04 PM
-- Edited by Chris R on Sunday 24th of March 2013 08:32:21 PM
More Pics:
Last of the Pics:
I want to say 750cfm, I will try to measure and do some cross referencing tomorrow to verify. The list # should be in one of the pics too.
Verified tonight... list # 3310-2 is 750 CFM. Let me know if you're still interested in the carb and/ or throttle cable. Fuel feed/ regs are gone.
