The owner took in a drip rail job on a stretch limo last week for me.......geeee thanks, Dave !!
Left side rail is mostly gone.
I've already fabricated 2 sections and welded them on the right side.
Getting the front section prepped for welding. Cut off the remaining rail, blew a bunch of holes in the replacement panel with the plasma for plug welding and sprayed everything with weld-thru primer.
After welding and grinding.
Starting on the left side. I couldn't believe a major limo conversion company would do this kind of work, but I guess once the padded vinyl top is put on, no one knows what's underneath it. Yes, that's bondo 1/4" thick !!
4 foot long center section replacement.
you sure do get the easy projects don't you
Was that Jimmy Hoffa's limo or something? Why on earth would they put that kind of coin in that?
No clue.......private owner and license plates too, not a rental. Maybe he has 6 kids.... 1991 Cadillac Brougham with only 96k.
