Using Tim’s old rims I was able to lower the Elky enough to raise the lift one more click (six inches) and park the Buick below it. I have two inches to spare between the Buick and the underside of the lift and two inches of clearance between the top of the Elky and the ceiling.
I know where there's a set of 15" rally rims not being used if you want them for the front. You might remember them since they used to be yours... That might drop the front by an inch or so if needed. Not enough for another click on the lift though.
And, you've got another inch clearance if you put the top down on the Buick, but it looks like you're good to go other than the Stang still being in a front stall.
Talk about a tight fit. Dang.
