I have 2 heaters I got from Menard's and used in my old house. They're part number CZQTV5M, google it for accurate specs. They work like radiant heat ones--no fan, just projecting the heat wave towards the area. Worked well enough for specific areas like over a work bench or a more focused area (15x15). Ceiling mounted, 2 settings: 760watt and 1500 watt. You could run them along one wall and separatte them for a broader range of projection. New garage already has built-in heat so I don't need them. Safer than gas since you don't need fresh air and they don't eat up the air in the garage, plus they're out of the way.
$40/pr.
