I am considering manual brakes for 72 Chvelle disc is front Wilwood discs in back Wilwood prop valve for rear. Currently not enough vaccum to keep good brake pressure. I have manual brakes in 68 Vette and they seem to work fine but much lighter car. Does anyone make a manual MC that works well in a Chevelle with discs all around ? I am seroulsy considering this to make room for getting valve covers off and generlly have good brakes and have more room.
ANY ideas suggestions ?
Any sizes work better ? any pedal mods ?
I was thinking of just trying a 68 Vette manual brake MC from AZ.
thanks in advance
I run a 70 Chevelle non power, disc brake master cyl in my 66SS. If I were you though, I would consider hydroboost setup like something off a Suburban and full size truck or a Astro/Safari van.
Sep 22, 2012
I have considered a Hydroboost. The only issue is I would have to run it off power steering pump. I hate my power steering pump no matter what I do it leaks and is a PITA to get to. Figure Manual would be one less failure point. I planned on Hydro boost this winter, but was looking to see if there is a manual setup that works well.
Call Wilwood and see if they have a disc/disc master. Any GM master can be used with or without a vacuum booster. The issue you have is that drum brake masters have a 4 lb residual valve to keep the wheel cylinder cups from leaking and that much pressure will cause pad drag on a disc.
I have a good '68 Corvette manual MC that you can try out... I'm currently not using it, so you can see if it works for you.
Sep 28, 2012
Thanks that may be a good idea. I thougth of trying a Vette manual MC.
thanks in advance
