You expect me to be around in the middle of the day ??? I'm not retired..............yet.
Reply Pm sent.
looks like backspace is 3.75"; but can't tell if the board is on the rim or the tire.
-- Edited by jim larson on Friday 10th of August 2012 01:10:11 PM
It's on the rim, Jim
For giggles, measure the front offset. I'm betting the wheel is a 7", not 8. The wheel width is measured where the bead seats on the inside of the lip.
GM, Kingsly Hays wheel. It is a 66, 67 Vette wheel.
-- Edited by dashboard on Saturday 11th of August 2012 09:36:15 PM
That just doesn't seem right.... are there any stampings near the valve stem to indicate it's an original GM wheel or is it an aftermarket ? I would have to test fit one on the Camaro to see if it will clear.
I'll be down that way next Saturday with the Camaro. Will you be around to try one on the car ?
Should be here, give me a call Friday for a reminder.
Mitch, check your PMs
Reply Pm sent.
