70 Chevelle small block ac/brackets/alt/water pump/pulleys/exh man/PS pump and gear box $50.
Last of my Elky parts. Pulled from the Elky. $50 gets you all the front accessories from an A/C car complete includes:
Main pulley
Water pump pulley
Water pump
Alternator + brackets
AC compressor + brackets
Exhaust manifolds - (nice shape)
Power steering pump + brackets
Steering gear box
John, kind of wondering about the ps gear box. Do you know if it was leaking fromt the seal area around the pitman shaft? And approximate number of miles.? I think my box is a little worn out as no more adjustment left on the adjustment nut and as thinking about swaping the pitman shaft and corresponding worn shaft and piston with parts from a used box if this parts aren't worn to bad. Thanks, Jim
No idea of the miles. It might have been replaced at one time. I can take a pic later and post it.
John. If this 350 thing works out with Mike/Bryan/Steve, I will very likely need all this stuff, However, I have to work out some logistics and make some space for this first. Dig out my engine stand, etc.
Main pulley
Water pump pulley
Water pump
Steering gear box
