I'll have to check the date on mine, I think it's April '69, and coded 3.73 posi. Bare housing. (probably not early enough???)
-- Edited by Derek69SS on Monday 30th of April 2012 01:09:05 PM
Yup, that's the one... give me a call after 4:00
-- Edited by Derek69SS on Monday 30th of April 2012 03:24:48 PM
Looking for a late 68 or early 69 12 bolt, complete, bare housing doesn't really matter as long as it is mecanically and cosmetically in good shape.
Thanks Derek,
If it is this one from way back whever I would be very interested in it.
(3) 12-bolts for sale
Printer Friendly
68 12-bolt 4.10 posi - just pulled it out of my car... Useable as-is, but the gears are noisy. I replaced the axle bearings and seals, and pinion seal when I put it in my car 3 years ago (around 15,000miles). Posi works good (1.84 60' times on 17" street tires!) Housing was in tough shape when I got it. Axle tubes are pitted a little bit. The lower brackets were all busted up from air-shocks, so I welded on good brackets that I cut off a 10-bolt. No brakes. SOLD
69 12-bolt bare housing w/caps... really nice housing coded for 3.73 posi (very desireable codes - can check dates if interested) $450
68-72 (I forget which) 12-bolt bare housing NO CAPS. SOLD
The backing plates are on it, but they're a little bent up from being slid around on the shop floor. Casting date is B 4 9 (Feb 4th 1969)
Will do it might be around 5. I got your phone number if you want to remove it from your post.
Thanks Derek,
Printer Friendly
