Hope to answer an old question on collector plates.
Recently someone asked me if I knew what the law was regarding collector plates. Well since I haven't worked traffic since 1972 (and never really did then since I was a lead foot and didn't want to be a hypocrite) I thought I would research it. There has always been confusion on this and I, as you, have heard the rumors of to and from shows and only xxx number of miles a year, etc., etc.
MN statute 168.10 Subd. 1c. states the car must:
1. Be 20 years old;
2. Manufactured after 1935;
3. The owner must prove they have one or more vehicles with regular license plated;
*AND NOW THE MEAT OF THE LAW*
4.Is owned and operated soley as a collector's item and not for general transportation purposes. This means you can drive to shows, to the repair shop, go for a Sunday cruise and you can "occassionally" drive it to work. What you can not do is drive it to and from work every day or even the majority of days. As always common sense prevails.
Unless an officer sees you abusing the priviledge there should not be an issue. Everyone has met the over zealous officer who may push his "authority", but the statute is pretty straight forward.
After researching the law I checked with MN DMV and they concurred. I also called an old friend who was one of those "traffic Nazis" we all fear. He also concurred.
Since there is some confusion maybe it is just best to print off a copy of MS 168.10, subd. 1c., and carry it in the glove box, that is what I am going to do.
If anyone knows of some statute I missed please let me know.
Jon, thanks for clarifying. This has been a favorite topic of discussion amongst the car community...
A few years ago I had one of Bloomington's finest follow me for a couple of miiles one early Friday morning when I drove the Chevelle to work. He followed me all the way until I turned into the parking lot, then he kept going. One of the 'friendly' accountants walked into work with me after I parked, and he sarcastically said "You know why the police followed you here don't you? It's because you had collector plates and aren't supposed to drive it for regular purposes, and it's only meant for parades and pleasure driving purposes." I told him "I have pleasure every time I drive it whether to a car show or occasionally to work!"
Now Jon, in your other spare time, can you clear the air on whether or not a front plate is needed on cars 20 years or older? That's the 2nd part of this debate... Thanks!
Ive asked cops about the Car Craft plate on the front before. I have asked some cops that they dont enforce it unless you really did something stupid. But I suppose that could depend on the cop. I ran my Car Craft plate on the front for years and never got hassled for it. Got the plate at the 2000 CC nationals and put it on right there at the show when I took it out of the goodie bag and it stayed in place for the next 5 years when I took the car off the road. Its actually still on the car.
Driver and Vehicle Services 445 Minnesota Street Suite 164 St. Paul, MN 55101
Collector class vehicles may display a single plate, on either the front or back of the vehicle owned or jointly owned by the applicant. (Emphasis and color added.)
Restrictions: Vehicles registered in any of the collector classes are restricted to operation solely as a collector's item and cannot be used for general transportation purposes.
Also, I have been looking for some original plates for my '69. I finally found some I liked and went into DMV to see if they were being used. The DMV is using a new format of 1 numeral, two alpha and 3 numeral plates like the original '68-'70 series, so that series of plates can no longer be used.
-- Edited by Jon H on Sunday 13th of November 2011 05:23:24 PM
-- Edited by Jon H on Sunday 13th of November 2011 05:24:27 PM
I just bought a set of '65 stamped with '66 sticker plates for my Chevelle with that same sequence. I suppose they won't register them now. So what happens to the vintage plates I already have registered on my '67 Camaro and '70 Chevelle?? Are they going to revoke them ? I've already paid for 2 sets of plates that the DMV rejected and guess what ....they won't return the money !!! They will credit it toward registering a different plate to the vehicle, which I haven't done, so they have over $90 of undeserved funds from me.
I have only had a rear plate on all my 20 yr old cars and never had any problem.
I would guess they will revoke them and you may be out of luck.
Nov 14, 2011
It is always a pleasure driving my cars. I had the Dodge county Sheriff himself in his Charger pull me over when I first got the Chevelle on the road in the middle of no where and he said he wanted to ask me to race him but when he got out of his car and he was able to hear it run clearer he figured he would lose : ) He was cool. He just wanted to make sure I had it registered as I had no plates on at the time and did not have the temp taped in rear window. Showed it to him and he said when I get home do not forget to stick it in the window.
I have orig MN plates on '67 Impala and '68 Vette. Good thing I got them on years and years ago vs now. I do not think they will revoke them the plates you have on your car now should be in there system as already used. If thye did I would Be PO big time. My Vette has and original MN 68 plate that is XXX 427 took a little while to find and some searching to get that plate for it.
-- Edited by Bowtieman427 on Monday 14th of November 2011 01:08:05 AM
If you havent already registered them by now. Its probably too late now to use them if this is the case. Anyone that got in before they changed could have got grandfathered in and will get to keep thier plates. Emphasis on could, who knows where they really stand. You could get replacement plates, or should I say, silk screened "sheets" with numbers and letters on them.
Nov 14, 2011
Since I've been a LEO for the past 15 years and a collector car owning gearhead, I get asked this question A LOT. The confusion comes from the laws lack of clarity.
The law states the collector car it is to be operated soley as a collector's item and not for general transportation purposes. NO WHERE in the law does it state anything about driving it to car shows, or Sunday driving, repair shops, or to work. And the most common one that everyone quotes to me "occasional pleasrure driving" DOESN"T SAY THAT anywhere in the statute.
So "operated soley as a collector vehicle" takes on many many interpretations. As Jon H said, As always common sense prevails. (unless of course you run into one of those "trafic Nazis") I myself am just going to keep using the common sense approch. It's worked for me for the past 20 years that I've had a vehicle with collector plates on it.
Also, if running one plate, it must be displayed to the rear.
-- Edited by Bungy L-76 on Monday 14th of November 2011 08:14:57 AM
I would also think the plate should be displayed on the rear of the vehicle, I am just quoting the DPS DVS website. In states where they only run one plate in must be displayed on the rear. If you put it on the front it is certainly going to get you stopped by a LEO more than you would like to be. Not a lawyer, so I can't answer that one.
I do cross my fingers when I make a Home Depot run.
"I'm bringing home materials for the garage it parks in...what's the problem Occifer ?"
-- Edited by Lost in the 60s on Monday 14th of November 2011 03:16:29 PM
"I'm bringing home materials for the garage it parks in...what's the problem occifer ?"
That should be with a capital "O" Mitch. LOL
My story was going to be. It’s for a calendar photo shoot Officer.
When I got collectors plates for my car, they asked if I wanted 1 or 2. Knowing I would only be displaying 1, I said 2 so I have one for the wall or whatever.
Thanks for the clarification Jon. I have asked several officers and DMV people, and also couldn't get a clear-cut in-writing answer either. Looks like it's a judgement call. Answer how you want if you get stopped, but if the same cop sees you on the same route at the same time several days in a row during the week, you're probably going to get tagged.
Clutch said
Nov 15, 2011
Back in 1996 I was going to school in Fargo and bought a 70 Z28 with collector plates in the cities. I stayed with my parents and on sunday drove the car back to school and got nailed by a trooper on I-94. He nailed me with a "illegal use of plates" ticket which was insanely expensive. His comment was that you couldn't drive a car with collector plates on an interstate freeway. I wish I would of fought that ticket because I think it was BS. I carry the statute in my car now just in case.
I was pretty mad with the dmv when they wouldn't let me register with my 68 plates. Sucks just so the state can collect money on all the specialty plates. Why can't I just pay the same custom plate fee and run them?
2 reason's; they use the same sequence again now as the vintage plates and they can't have duplicate numbers and they sure as heck aren't going to skip the vintage numbers now registered for us.
Second reason; they want ALL cars to have the digital plate soon so the officers don't need to read them. They have a scanner to do that. Big Brother wants to know where everyone is and what they are doing. Maybe at some point in this government take-over, the people will finally unite and speak out about all the liberties we have lost and are continuing to loose and demand that the GOVERNMENT do as WE say. Most levels of government have taken the lifting of our privacy as a result of Homeland Security WAAAAAAY beyond reasonable and used it against us to spy and control.
Where's Pushrod ?? This should get him fired up...
Mitch,
Do you really want to poke the sleeping bear?
Mitch,
So I guess if I want to build an old school 31 coupe or a rat rod style car. I cant use the original 20's and 30's era rusty license plates either then. The street rodders are not going to be happy with that.
Only if the way the numbes and letters were arranged in those particular years is in conflict with current issue plates, otherwise they are good to go.
Pushrod said
Nov 16, 2011
Well, im awake but if i get going on our current administration ,you know, chimp boy, and all the other crap going on.... ( occupy mn, our governor and i use that term loosely, GOP candidates , why they have to mess around with regulating the HE double hockey sticks out of every thing ,my freedom to make my own decisions and so on and so forth ) ill go NUTS!!!! besides this isn't the place to discuss my opinion on "politics" i woulnd't want to OFFEND anybody. oh-oh my face pic is on here, here comes the thought-police
-- Edited by Pushrod on Wednesday 16th of November 2011 08:38:16 PM
Kevin, Kevin Kevin, you just had to poke the sleeping bear didn't you!
I just got back from the DMV to pick up tabs. I asked the person behind the counter about this. It seems its correct, at least from what I gathered from what I was being told. Although, I was referred to a phone number to call and really get these questions answered. The office in St. Paul whom has all the answers.
Appearently the last few years, the state has really started cracking down on the use of collector cars as collector car plates started to become more abused lately. Guys have been using collector cars as normal transportation a lot now and the state finally started to do something about it and enforce it.
She gave an example of a guy that drove a car with collector plates for years as basic transportation and the law caught up with him. They went back into the history and charged him with paying for registration for at least the last 5 years, he got multiple fines, plus he was fined another 5 grand and they wont allow him to get collector plates on any car ever again. That was an example I was given. The only thing we can really do is call the state and bring the actual plate into the DMV and show them what you have. Ill grab the card I was given and post the number if anyone wants.
Clutch said
Nov 19, 2011
From what the woman told me, that is pretty much every plate configuration every made since they have so many speciality plates to try and squeeze more money out of everyone. It's all about the money.
1. Be 20 years old;
Stan,
I like your definition of "pleasure driving"!
This is from the DMV website. One is good.
Applications for registration in one of the collector classes must be made at a Deputy Registrar Office or by mailing an Application to Title and Register a Vehicle (PS2000) and the appropriate fees to:
St. Paul, MN 55101
Mitch,
