I'm tired of carb issues, cold starts, poor economy, etc., so I started thinking about this. I'm only in the research phase, but I have started thinking of posting my current engine/trans combo for sale in case anyone wants to see/hear it before it was pulled...
I'd like to keep my Chevelle stock looking on the outside other than some different rims, but with modern performance/convenience i.e. the Delky mobile. The good thing is that my car isn't numbers matching, documented, or even the original color, so doing something like this probably wouldn't hurt anything.
The other thing is I have a background in electronics, and enough mechanical skills to be dangerous, so this might be a fun and challenging project.
And no... I'm not selling it already!
-- Edited by SShink on Tuesday 20th of September 2011 11:54:48 AM
Sep 20, 2011
You wouldn't regret it Stan. I really enjoy driving mine now. There are lots and lots of options for motor mounts, oil pans, etc. I reworked my own harness, they aren't as bad as they look. Turn the key and go!
-- Edited by SteveS on Tuesday 20th of September 2011 12:10:37 PM
I am going to completely resist the urge to open the link to that site, completely resist. Not going there, going to force myself not to even peek at the LS thing site.
Think a guy could put a new Kessler RS 500 five speed overdrive behind one of those LS deals?
I just started tearing down my Elky Sunday night for the LS1/T56 this winter.
So far the front clip is off and I am ready to pull the engine / transmission.
I'll post pics along the way.
Please start a thread so that we can learn from you!
One of my 'unkowns' is what tank to use for the electric fuel pump that looks stock without having to modify it with a sump. I saw a few things on LS1tech.com in regards to solutions for that.
Kevin,
You can put one of those transmission behind an LS engine. Though I would go with a T56 myself from an LS1 f-body.
-- Edited by Enganeer on Tuesday 20th of September 2011 12:48:47 PM
You can keep your 200-4r and put an ls motor in front of it. No need to sell off the transmission you just spent all that money on.
I thought about that, but also thought that with all the electronic controls of a 4L60E, it might be a nice combo to be able to tweak shift points, adjust for tire size, etc. Or, if I find 5.3 litre engine with the trans, it might be a better deal overall.
That's the fun part about a project like this... thinking of all the options.
I am sure Derek has many answers already. The B-body tank comes to mind with a little trimming of the frame.
My donor car was a Camaro and the fuel tank is a side fill just like the elky . I just need to see how the tank mounts underneath in regards to depth (hanging down too far). Width wise, it looks ok.
In your shoes, I'd go with the Spectra tank... perfect for a mild street car that's not going to be roadracing or needing to feed 600hp.
I'd also stick with the 200-4R for its gear ratios which are WAY better than the 4L60e.
Best way is to find a donor vehicle, preferably 2wd or F-body. Strip off everything you think you could possibly use and bag and tag. This way, your not chasing down little parts.
I found a ls1 camaro and stripped it bare. Sold off what I did not think I would use to recoupe some money.
This is what I was after
If I had room, I would pick a later 3500 series van from a salvage auction. Here is one from a charity auction that ends Wednesday. 6 liter, 4l80E transmission, computer, harness, fuel system, etc. Not bad starting point
Scroll down about 1/2 way and it talks all about them.
No cold start or carb issues here and around 15mps. Thought we had close to the same thing. Good luck, should keep you busy.
Sep 20, 2011
The spectra tank at Rock auto is the cheapest, they are supposed to have reworked it to stop the fuel starvation issues they had. First gear in the 4L60e is too low, but I do like all the changes that can be made with the computer. If I were to do it again, I'd go T-56.
I've got 4.11 gears, so even with the 0.67 overdrive I'm running at 2400 rpm at 65 mph and only getting 10-11 mpg. That works well with the 2400 stall converter, but not what I was hoping for.
A 3.73 gear would probably be just right.
Ok thats enough, now get back to work guys!
Why in the "Aich E Double Hockey Sticks" did you put this on here!!
Now you've got me thinking again...
(Yeah, I'm about 10 or so years "behind the curve" with the LT-1/4L60, but...)
Frankly, I'd stay away from ANY "Fleet Vehicles" that are on auctions. As the driver of said, we're on a 5000 mile oil change interval, only authorized to use conventional (dinosaur sauce) oil, the hood ONLY opened to top off wiper juice, and you think that people beat on rental cars??? Try a company truck - they're run at capacity or overloaded 90% of their life. The only fleet truck I'd consider is a low mileage, rear-end wreck, or a "boss's/supervisor's" pickup.
Added a new post for my LS1 conversion start.
You should be doing better than 10-11 mpg with the current setup. Is your speedo reading correctly ? Just change the gears and see how it is. Much cheaper than an LS1 swap.
If you truely take the LS route, an aftermarket tank built for a stock GM pump is the way to go. Install the corvette filter/regulator at the back and you don't need a return line. I did this on a Camaro last year and it was a simple swap. The owner opted for a stainless tank from Rick's.
Oh, and put me first on the engine buyer list !!
Speedo is spot on. I added an adaptor from the speedo shop guy in Bloomington that Master Trans sent me to, and it adjusted everthing perfectly. Speedo/Odometer match exactly with GPS.
I was hoping for around 14-15 mpg, but not even close. I just swapped on a new carb hoping that helps as I got tired of messing with jets. Haven't checked the mileage yet.
You have first right of refusal if I decide to sell the 402...
Did you go to an Edelbrock carb ? I have one on the Camaro and really like it. I was a die-hard Holley man until then. The Chevelle has a Holley and it seems to do well but no fuel gauge to check mileage.
Yep, Edelbrock 750 cfm w/vaccum secondaries.
BB502 said
Sep 20, 2011
Stan, If you decide to sell the tranny and go with the newer one I would be interested in the 200r4.
Got it. I'll keep you posted.
I think Stan’s major fuel economy penalty is that little trap door flapper thingy on his hood, he seems to enjoy seeing it open all the time.
That was my thought too. If he puts an LS engine in, it can stay open all the time because there's no way to utilize it on the intake.
Sep 22, 2011
For you guys looking into LS engines, here are some more sites that were helpful to me:
-- Edited by SteveS on Thursday 22nd of September 2011 08:40:02 AM
Got my issue of Super Chevy yesterday, and guess what? They are doing a series on the 5.3 LS engine!
I haven't read it yet, but scanned it quickly and noticed that in stock trim (exhaust manifolds and all) their baseline 5.3 had as much HP and Torque as my 402 right out of the box (350 hp/380 ft. lbs.)! And it's almost 100 c.i. smaller and much more efficient too...
The max hp and torque was at a higher rpm (5600) than my 402, but with the right trans it would move the Chevelle right along.
In the article, they make progressive changes with cam, heads, and intake and I think they end up just under 600hp, but need to read it again to check.
Stan, do you have the 5.3 in your truck ? I have it mine and for a 6,000 lb vehicle, it gets up and moves...
I forgot mention that too... yes, my 2003 Sierra has a 5.3 and it has tons of torque and idles at 500 rpm. I get 17-20 mpg depending on how I drive it, which I think is good for a full size extended cab 4 X 4 truck.
So, now I can go out in the garage and stare at the 5.3 and consider the swap...
If it's dead quiet and you listen hard enough, you will hear it whisper to you.
You can head over to AAA in Rosemount and pick one up for around $500 or less.
Sep 22, 2011
If your going iron block, I'd check the price difference between a 5.3 and 6.0. Costs the same to install either one.
That's what's scaring me... AAA is less than 60 seconds from my house! I'm afraid that the next time I get home a little early, I will feel the force pull me over there to see what they have on hand.
If it's only a couple hundred more, I'd go 6.0. I think they are physically the same other than the 6.0 has a 4" bore?
6.0L have been going for about double of 5.3L that I have seen. Main reason is there are so many 5.3L available.
Makes sense. Good 'ole supply and demand at work.
Found this one on AAA website from a 2003 Silverado for $500 with 96K miles (only half broke in )
Part Description:
Engine Assembly 180-180,C50,HC-NA, X-337,ETC
Price:
$500.00
Condition Code:
0.0
Mileage:
96,000
Grade:
Primary Damage Code:
Secondary Damage Code:
In the 100-139K mile range they are $400, and in the 140K+ they are $375.
Looking back to a year ago... I could have bought an entire engine assy for what I spent on fixing the heads on my 402... But at the time, I was all about keeping it stock looking too.
-- Edited by SShink on Thursday 22nd of September 2011 11:17:25 AM
-- Edited by SShink on Thursday 22nd of September 2011 11:21:03 AM
Brad Wilder did up a 6.0 for his 57 project so you can also tap him for some ideas and opinions on what he did and didnt do since he has real world expierence as well.
I emailed AAA and the $500 one is only a long block. No ECU or accessories. I sent them another email asking if they have any complete ones, and the price.
You got the fever...only one cure...more cowbell!
Nice SNL reference. Hopefully I'm not Will Ferrell in the shirt that's too short!
bwild70ss396 said
Sep 23, 2011
My 6.0 was $2300 from AAA in Rosemount with all accessories, flywheel, exhaust manifolds and computer. Had 8k miles on it and 352hp stock and big heads on it for easy hp increase. My very mellow cam made 469hp with the tune and headers. I also am watching build of that 5.3 in Chevy mag. Only downside of truck motor is the cast pistons so you cant twist them to high.
-- Edited by bwild70ss396 on Friday 23rd of September 2011 02:32:50 PM
Sep 24, 2011
Not to add fuel to getting an LS1 there is an article in November Super Chevy P48 "Here Comes Modern Mouse" about 5.3 LS1 upgrades. It will be a 3 part series.
Not to add any fuel to the fire, but I was going to do a basic overview of the LS engines for the next newsletter......
Sep 24, 2011
This topic is killing me have not bought anything accept a block for the 383 build this winter, this LS idea is making me rethink the whole idea. LS may be a better soulton for the long haul.
No more thoughts about LS engines and fuel injection. The Chevelle ran great today! I guess I'm !
BB502 said
Sep 24, 2011
Mine runs good in the 50's also.
Is this the first time out with the new Edelbrock ? I think you'll like it. No power valve or finicky jet issues. Just drive it....
Big blocks like low temps and high humidity.
Yep, Stan stopped by this afternoon with that big grin on his face; the Velle is running well.
BB do like cool temperatures; I really enjoy driving mine when it’s cool out.
No, this wasn't the first time with the new Edelbrock, but I had problems with it wanting to die last Sat. when going to Hastings. Started it up today and discovered the idle circuit screws were in too far, and probably the bigger factor was I found the vacuum line for the flapper door had come off the vacuum T, so I had a huge vacuum leak!
That darn flapper door anyway... always seems to get me in trouble!
I was poking around the internet last night, and thought I'd check into what it would take to drop in an LSX engine and found the LS1Tech forum.
I think Derek, John E., and Andy have already mentioned this site, but I just started digging into it.
Here's an article on a low budget install for less than $1500 (engine only):
http://ls1tech.com/forums/conversions-hybrids/1075693-my-budget-ls-engine-swap-guide-1500-a.html
Kevin,
http://www.keislerauto.com/gm/gm-parts-and-accessories/bellhousings/chevrolet-super-duty-11-bellhousing-only-late-model-ls/shop.flypage_acc.html
Go on and peek inside LS1tech, it's free...
http://www.charitycarauctions.com/cgi-bin/mnlist.cgi?charitycar2/63970M
(fixed link)
-- Edited by Enganeer on Tuesday 20th of September 2011 01:39:28 PM
There is a company now making a new gear cluster for the 700r4 so first gear is 2.84 I think but they are not cheap.
http://www.transmissioncenter.net/highperf700r4.htm#Parts
Tips for modding an LS1:
http://www.ls1howto.com/
S&P's site lots of builds & Tips:
http://www.hotrodlane.cc/New%20LS%20Links%20Page/LS%20links%20page.html
3 part GM High Tech Performance article on Strokers:
http://www.gmhightechperformance.com/tech/lsx_engine/0608gmhtp_big_cube_ls1_engine_build/index.html
LS1 guide to tuning:
http://ls1tuningguide.com/tuninghelpfiles.php
Cruise control Wiring:
http://www.thirdgen.org/techboard/ltx-lsx/552764-digital-cruise-ltx-lsx.html
